First post, by jim78b
vorrei usare lo schema dei colori CGA in window xp, qualcuno sa i codici e come metterli per usarli nel desktop di window?
BEST REGARDS
Reply 3 of 17, by Great Hierophant
Here are the RGB values for the 16 CGA colors :
Color                Hex Value       R   G   B
Black 00h 0 0 0
Blue 01h 0 0 170
Green 02h 0 170 0
Cyan 03h 0 170 170
Red 04h 170 0 0
Magenta 05h 170 0 170
Brown 06h 170 85 0
White (Light Gray) 07h 170 170 170
Gray (Light Black) 08h 85 85 85
Light Blue 09h 85 85 255
Light Green 0Ah 85 255 85
Light Cyan 0Bh 85 255 255
Light Red 0Ch 255 85 85
Light Magenta 0Dh 255 85 255
Yellow (Light Brown) 0Eh 255 255 85
High Intensity White 0Fh 255 255 255
Reply 6 of 17, by elfuego
jim78b wrote:
YES THE 4 COLORS OF CGA! BUT HOW I CHANGE AND SET THEM IN WINDOW? HAVE YOU SUGGESTION?
BEST REGARDS
1) Right click on desktop, click properties.
2) Select Appearance tab
3) Click Advanced
4) Click on the element you want to edit and click on "Color"
5) Click "Other"
6) Insert color value from the above table
Enjoy 😀
Reply 11 of 17, by Pippy P. Poopypants
jim78b wrote:
vorrei mettere in proprieta -> impostazioni di window non 65.000 colori ma 4 colori in modo che window li misceli automaticamente con tutto, perfino per le icone, è possibile?
Are you talking about running the Windows XP desktop in 4-color mode? The lowest I've ever seen anyone get it down to is 16 colors (i.e. standard VGA). Other than that, you'll pretty much have to resort to screwing around with the appearance settings.
GUIs and reviews of other random stuff
Вфхуи ZoPиЕ m
СФИР Et. SEPOHЖ
Chebzon фt Ymeztoix © 1959 zem
Reply 13 of 17, by Jorpho
jim78b wrote:
then you can not do as I say?
We don't know what you said, because we can't read your language!
ToastyTech has a few shots of Windows 95 running in very low-color modes, but I doubt the same tricks can be applied to Windows XP.
http://toastytech.com/guis/misc2.html
Reply 15 of 17, by jmrydholm
(I speak Alienware!) 🤣
    2.28 KiB
"The height of strategy, is to attack your opponent’s strategy” -Sun Tzu
“Make your fighting stance, your everyday stance and make your everyday stance, your fighting stance.” - Musashi
SET BLASTER = A220 I5 D1 T3 P330 E620 OMG WTF BBQ
Reply 16 of 17, by Pippy P. Poopypants
Just for your reference, here's each RGB palette in normal and high intensities.
http://uncyclopedia.wikia.com/wiki/Monitor#Co … apter_.28CGA.29
Enjoy the humor too. 😀
Вфхуи ZoPиЕ m
СФИР Et. SEPOHЖ
