The Ultimate 486 Benchmark Comparison
Reply 40 of 283, by feipoa
Tetrium, nice find!
One model (ESA-TF486, MB103) has:
PS/2, 512 KB cache, 128 MB EDO RAM, 128 GB IDE harddrive support, Cyrix/AMD 5x86 support, IrDA, ALi chipset, AWARD BIOS, but only 1 PCI slot
While some (ESA-486AVR-128) take PC100 SDRAM, have onboard graphics, and a USB header. These can also take a mini-PCI card for SATA or gigabit ethernet. However this model uses a soldiered-in ZFx86 CPU with maximum 100 MHz.
Almost worth consideration if it wasn't over $300x10 and had 3 PCI, or PCI-E, ports. Actually, I'd even consider the ESA-MB103 model right now if the price was right (less than $50). I can get away the onboard IDE and an ISA NIC.
I'd be surprised if any of the late-model PCI-based 486's made it into mainstream industrial automation, let alone a PC Chips M919. It seems the main interest lies in ISA slots, where pre-PCI era 486 boards were loaded with ISA slots.
Reply 41 of 283, by Tetrium
Bigger pic of the ALI board
http://www.tradenote.net/images/users/000/224 … ages/191496.jpg
And the complete list of that other manufacturers 486 boards. Now I want to see more 🤣!
http://www.esapcsolutions.com/industrial-moth … s-c-45_109.html
My retro rigs (old topic)
Report spammers here!
Reply 42 of 283, by feipoa
The ALi board seems to be substantially older -- the manual's date is 1999. I sent the company an e-mail inquiring about current pricing and availability. I asked for a quantity of 1 and for 5.
Reply 43 of 283, by feipoa
There has been some talk of the POD100-WB in the other thread, although this probably belongs in this thread as it relates to the said scores.
To clarify, the only benchmark test that the POD100-WB didn't work with was the Quake Timedemo. Please read the footnote. The inserted value was linearly extrapolated from the data of POD83-WB, POD83-WT, and POD100-WT.
The working score of the POD100-WT in Quake is 23.6 fps.
Reply 44 of 283, by Tetrium
It's a shame really that Intel never bothered to release a 100Mhz POD chip for Socket 3. Would've been awesome 😁
One thing that makes Socket 3 so interesting is that it's CPU's were being manufactured right to the end of the last millennium, even though for industrial purposes mostly. Those chips would be interesting to find out their overclocking potential 😁
Reply 45 of 283, by sliderider
What would have been better is if they just didn't lock the multiplier. There really was no reason to lock it. Officially, only the DX-50 motherboard or the 40mhz AMD setting would have overclocked it. Almost nobody knew about the undocumented bus speeds on some of the late PCI boards back then.
Reply 46 of 283, by Tetrium
True, but Intel decided to lock all of their overdrive processors (because Intel considered it's customers to be too stupid to know what a multiplier is? 😜). Shame they never released a non-overdrive Pentium for Socket 3 but I guess they only made these POD's because they had promised to do so
Edit:The whole point of the overdrive family was that you only needed to plug it in et voila, upgrade complete 😜
Reply 47 of 283, by DonutKing
yeah, this was my understanding as well, and many 486 boards didn't have multiplier adjustment.
Reply 48 of 283, by feipoa
Scans of the actual CPUs employed in this study have been added to the beginning of the thread. Scans were done using a retro UMAX Astra 600S SCSI scanner, purchased in 1997. The optics are starting to go as evident by the vertical/horizontal colour striations.
Reply 49 of 283, by Tetrium
Very nice!!
And you got a Cyrix 5x86-80?? Never knew these existed!
Reply 50 of 283, by feipoa
Actually, I have two! The only Cyrix 5x86 I'm missing is the 5x86-120/4X. I did not include duplicates of any CPU in this scan, even if the S-spec was different -- that would have made for a lot of Intel DX2's.
I have updated the PDF and text to reflect the comments and observations made by others. Thanks to everyone!
When I have the time (and motivation), I'll add the AMD DX4-100-WB-16KB to the list for improved clock-for-clock comparisons.
I cleaned up the CPU scan a bit to.
Reply 51 of 283, by feipoa
Attached is a PDF comparing the AMD DX4-100-WT-8KB vs. AMD DX4-100-WB-16KB. Significant improvements are highlighted. Some benchmarks show significant improvement, while most show negligable improvement (like Quake, Pcpbench, and 3Dbench).
The performance might match that of the Intel DX4-100-WB-16KB. I think I'll replace the AMD DX4-100-WT-8KB in the charts with the WB-16KB version and make a note of the overall differences. I can't see any reason to keep both when the results will be pretty similar, can you? The AMD DX4-120-WB-8KB will still outperform the DX4-100-100-WB-16KB.
Any thoughts?
EDIT: Bah, maybe I'll keep both on the chart. One reason I don't want to add another column is because it doesn't print as well due to scaling.
    AMD_DX4-100_Comparison.pdf
    70.34 KiB
    399 downloads
    Comparison of AMD DX4-100-WT-8KB vs. AMD DX4-100-WB-16KB
Reply 52 of 283, by feipoa
Here's a follow-up from the ESA motherboard.
ESA TF-486 (MB103) went non-production recently (less than a year ago), but there are a good 50K of them living out there. The reason they went non-production was because they couldn't get the ALI chipsets anymore. To continue prodution, they would have to put in a custom chipset order for 20K chipsets, which they decided not to do, or to buy used desoldered chipsets, which they decided not to do for reasons of contact oxidation, cleaning, prepping, and uncertainty in quality.
ESA no longer has an inventory of the TF-486. It was a great selling board. So the only other new option they offer is the ESA-486AVR-128, but you are stuck with the soldered-in custom processor. It does have a working USB port though.
Reply 53 of 283, by feipoa
AMD DX4-100-WT and AND DX4-100-WB CPUs have been added to the official PDF and PNG images. The monologue has also been updated to reflect this change.
I suspect this will be the last required update.
EDIT: Bah, this is like writing a journal publication -- you're never really finished. I've added to the text, pdf, and png images data for an AMD X5-180, AMD X5-200, and a Cyrix 5x86-150. Values were linearly extrapolated from the data of AMD 66, 100, 133, and 160 and Cyrix 80, 100, 120, 133.
Reply 54 of 283, by sebaz_ri
@feipoa
i think that the "Ultimate Socket 7 Benchmark" should be with the processors:
AMD K6
AMD K6-2
AMD K6-2+
AMD K6-3
Cyrix 6x86
Cyrix 6x86MX or MII
Intel Pentium MMX
Intel Pentium PRO
but... first we must overclock this processors up to the highest frequency
my records:
AMD K6-2 533 overclocked to 570 (95x6)
Cyrix M-II 233GP overclocked to 300MHz (100x3)
on a PCChips M598LMR board
Reply 55 of 283, by swaaye
sebaz_ri wrote:
@feipoa i think that the "Ultimate Socket 7 Benchmark" should be with the processors: AMD K6 AMD K6-2 AMD K6-2+ AMD K6-3 Cyrix 6 […]
@feipoa
AMD K6
AMD K6-2
AMD K6-2+
AMD K6-3
Cyrix 6x86
Cyrix 6x86MX or MII
Intel Pentium MMX
Intel Pentium PRO
Pentium Pro is a Socket 8 CPU.
Also,
Intel Pentium Classic (has half the L1 of PMMX)
Centaur Winchip / C6
Centaur Winchip 2
AMD 5k86 (SSA5)
AMD K5
Making a comprehensive Socket 7 comparison is going to be a lot of work...
Reply 56 of 283, by Tetrium
swaaye wrote:
Pentium Pro is a Socket 8 CPU. […]
@feipoa
AMD K6
AMD K6-2
AMD K6-2+
AMD K6-3
Cyrix 6x86
Cyrix 6x86MX or MII
Intel Pentium MMX
Intel Pentium PRO
Also,
Centaur Winchip 2
AMD 5k86 (SSA5)
AMD K5
And don't forget the Rise mP6 😉
And I reckon a good 2.2v sample MII chip could be overclocked to say 400Mhz.
And don't forget Tillamook (if we ever get the hecked chip running with L2 cache -_-)
Reply 57 of 283, by sliderider
Tetrium wrote:
And don't forget the Rise mP6 ;) […]
@feipoa
AMD K6
AMD K6-2
AMD K6-2+
AMD K6-3
Cyrix 6x86
Cyrix 6x86MX or MII
Intel Pentium MMX
Intel Pentium PRO
Also,
Centaur Winchip 2
AMD 5k86 (SSA5)
AMD K5
Rise mp6 was only sold in Asia-Pacific markets so not many people outside that area ever got to use one. Even now it's hard to find one outside that area. The only seller that has them on ebay is the same one that sells the Tillamooks for $20 and his asking prices are outrageous. A real Pentium MMX or Pentium II of the same clock speeds is a lot cheaper and faster.
Reply 58 of 283, by feipoa
I currently have plans for a similar socket 7 comparison whereby all socket 7 CPUs will be tested on the same system. For completeness, I will include the PII-400, Cyrix 5x86, and POD results, in which case the results will no longer strictly be socket 7. A loosely translated title of this type of comparison may read, The Ultimate 586 Benchmark Comparison.
The CPUs in this study will include:
Cyrix
5x86 - 100 MHz (33 MHz x 3.0) for comparison against 6x86-100
5x86 - 120 MHz (40 MHz x 3.0) for comparison against 6x86-120
5x86 - 133 MHz (33 MHz x 4.0) for comparison against 6x86-133
6x86 - 75 MHz (50 MHz x 1.5)
6x86 - 90 MHz (60 MHz x 1.5) - U
6x86 - 100 MHz (66 MHz x 1.5) - U
6x86 - 120 MHz (60 MHz x 2.0)
6x86 - 133 MHz (66 MHz x 2.0)
6x86L - 150 MHz (60 MHz x 2.5)
6x86MX - 166 MHz (66 MHz x 2.5) - U
6x86MX - 200 MHz (66 MHz x 3.0)
MII - 233 MHz (66 MHz x 3.5) - U
MII - 250 MHz (83 MHz x 3.0)
MII - 266 MHz (66 MHz x 4.0) - U
MII - 300 MHz (75 MHz x 4.0)
MII - 333 MHz (83 MHz x 4.0) - O
Intel
P24T - 83 MHz (33 MHz x 2.5)
P24T - 100 MHz (40 MHz x 2.5) - O
P54C - 75 MHz (50 MHz x 1.5)
P54C - 90 MHz (60 MHz x 1.5)
P54C - 100 MHz (66 MHz x 1.5)
P54CS - 120 MHz (60 MHz x 2.0)
P54CS - 133 MHz (66 MHz x 2.0)
P54CS - 150 MHz (60 MHz x 2.5) - U
P54CS - 166 MHz (66 MHz x 2.5)
P54CS - 200 MHz (66 MHz x 3.0)
P55C-MMX - 100 MHz (?) - U
P55C-MMX - 166 MHz (66 MHz x 2.5) - U
P54C-MMX - 200 MHz (66 MHz x 2.5) - U
P54C-MMX - 233 MHz (66 MHz x 3.5)
P54C-MMX - 266 MHz (66 MHz x 4.0)
P54C-MMX - 300 MHz (75 MHz x 4.0) - O
P54C-MMX - 333 MHz (83 MHz x 4.0) - O
PII - 400 MHz (100 MHz x 4.0)
AMD
K5 - 100 MHz (66 MHz x 1.5)
K6-2 - 100 MHz (?) - U
K6-2 - 266 MHz (66 MHz x 4.0)
K6-2 - 300 MHz (75 MHz x 4.0) - O
K6-2 - 500 MHz (83 MHz x 6.0) - U
K6-3+ - 400 MHz (66 MHz x 6.0) - U
K6-3+ - 450 MHz (75 MHz x 6.0)
K6-3+ - 500 MHz (83 MHz x 6.0) - O
IDT
Winchip - 200 MHz (66 MHz x 3.0)
Winchip2 - 233 MHz (66 MHz x 3.5)
Winchip2 - 266 MHz (66 MHz x 4.0) - O
In cases where I do not have the actual CPU at the specified frequency, a closely matched CPU will be benchmarked in its place (slightly over/under clocked, provide that the CPU architecture is the same). U stands for an underclocked CPU while O stands for an overclocked CPU. The clock frequencies noted are actual clock frequencies, not the PR rating using by IDT, Cyrix6x86/MII, and AMD K5's. For example a Cyrix MII-400GP will be used for the 300 MHz test.
It will be interesting to do a clock-for-clock comparison at 100 MHz with POD100, Cyrix 5x86-100, K5-100, Intel100, Cyrix 6x86-100, and perhaps too the the K6-100 and MMX-100 if they will downclock well.
Is there any CPU of particular interest I have left out? I can only go up to 500 MHz for AMD and 333 MHz for Cyrix. If the Intel CPU's are locked, then I am stuck with a 4x multiplier, for which 333 MHz will be the max I can test on this non-super socket7. The BIOS has been modified to allow for proper K6 II/III+ operation as well as Cyrix 4x, with a maximum FSB of 83.3 MHz.
