Old Win95,98,ME Games
First post, by BoardX
DOS BOX should be extended, by being able to start also Games, only under Win95,98, ME is executable. I use Win7 64Bit and get the Game Dracula Resurrection to do not run correctly.
Reply 2 of 12, by Zup
Have you noticed that the program is called DOSBox? Surprisingly, the authors didn't want to call it Winbox, Windowsbox, 95box or something like it... may it be that they didn't want to support Windows games?
BTW, there are a lot of compatibility settings that you can change using ACT, or you could try using Linux+Wine.
I'm selling some stuff!
Reply 3 of 12, by mr_bigmouth_502
Once I learn C, I will create the much sought-after "Winbox", but until then you'll either have to learn how to install Win95 in DosBox, or better yet, run it in a legit VM such as Bochs or Virtualbox.
Reply 4 of 12, by wd
Rank DOSBox Author
DOSBox Author
Yeah, better learn C first.
Reply 5 of 12, by leileilol
don't forget that x86 asm.
Debian's fucked
Reply 6 of 12, by swaaye
why emulate it? just be awesome and write us a new OS that can run everything. 😀
Reply 7 of 12, by BoardX
A new Box that can run all old DOS and Win Games.
Reply 8 of 12, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
How many man/woman-hours went into Wine so far? 😁
1+1=10
Reply 9 of 12, by Jorpho
BoardX wrote:
DOS BOX should be extended, by being able to start also Games, only under Win95,98, ME is executable. I use Win7 64Bit and get the Game Dracula Resurrection to do not run correctly. 😒
I don't suppose you bothered Googling at all before coming to the conclusion that unreasonable demands would be the best solution to your problem?
Apparently the game requires hyperthreading to be disabled.
http://www.gameboomers.com/Members/legacygame … erthreading.htm
Reply 10 of 12, by BoardX
White someone where it in the Web one for Win7 compiled Wine version gives, which one can start immediately?
Reply 11 of 12, by wd
Rank DOSBox Author
DOSBox Author
Read what Jorpho posted.
Reply 12 of 12, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
This sounds like someone used google translate on each word, translating it from German 😉
BoardX, you should let google translate whole sentences instead of translating each word.
Du solltest Dir gesamte Sätze übersetzen lassen, anstatt Wort für Wort, und wenn Du schon so übersetzt, dann nimm den richtigen Wortstamm (z.B. wissen anstatt der Farbe Weiß).
