First post, by BoardX
DOS BOX should be extended, by being able to start also Games, only under Win95,98, ME is executable. I use Win7 64Bit and get the Game Dracula Resurrection to do not run correctly.
Better get cracking then.
Have you noticed that the program is called DOSBox? Surprisingly, the authors didn't want to call it Winbox, Windowsbox, 95box or something like it... may it be that they didn't want to support Windows games?
BTW, there are a lot of compatibility settings that you can change using ACT, or you could try using Linux+Wine.
Once I learn C, I will create the much sought-after "Winbox", but until then you'll either have to learn how to install Win95 in DosBox, or better yet, run it in a legit VM such as Bochs or Virtualbox.
Yeah, better learn C first.
don't forget that x86 asm.
why emulate it? just be awesome and write us a new OS that can run everything. 😀
A new Box that can run all old DOS and Win Games.
How many man/woman-hours went into Wine so far? 😁
1+1=10
wrote:DOS BOX should be extended, by being able to start also Games, only under Win95,98, ME is executable. I use Win7 64Bit and get the Game Dracula Resurrection to do not run correctly. 😒
I don't suppose you bothered Googling at all before coming to the conclusion that unreasonable demands would be the best solution to your problem?
Apparently the game requires hyperthreading to be disabled.
http://www.gameboomers.com/Members/legacygame … erthreading.htm
White someone where it in the Web one for Win7 compiled Wine version gives, which one can start immediately?
Read what Jorpho posted.
wrote:White someone where it in the Web one for Win7 compiled Wine version gives, which one can start immediately?
This sounds like someone used google translate on each word, translating it from German 😉
BoardX, you should let google translate whole sentences instead of translating each word.
Du solltest Dir gesamte Sätze übersetzen lassen, anstatt Wort für Wort, und wenn Du schon so übersetzt, dann nimm den richtigen Wortstamm (z.B. wissen anstatt der Farbe Weiß).
