VIDEO - CGA w/ Monochrome Monitor Support
Here you can discuss the development of patches.
Re: Patch & Test Build - CGA w/ Monochrome Monitor Support
Postby VileRancour » 2011-9-07 @ 19:04
ykhwong wrote:I am using d3dx9_42.dll released in 2009 instead. What's the matter with the shaders? I modified several shader files about two months ago so that they should work properly with it.
using the DLL from your build produces errors:
Code: Select all
D3D:Using triple buffering
D3D:Error in pixel shader shaders\CRT.D3D.fx:
Unable to create effect compiler from shaders\CRT.D3D.fx
D3D:Pixel shader output disabled
Not sure how to get more details.
Using d3dx9_30.dll (renamed), it works fine - no other changes; .conf file and shaders\ dir contents are the same.
I also tried several other shaders with a modified date of July 5 (Lanczos.fx, bilinear.fx, Sketch.fx), and they result in the same error using the _42 dll, but work fine with _30.
User avatar
VileRancour
Postby ykhwong » 2011-9-08 @ 04:59
VileRancour wrote:
Code: Select all
That is weird. What is your video card? Did you update your video driver to the latest version?
ykhwong
Postby VileRancour » 2011-9-08 @ 09:03
Nvidia geforce GT 240, with the latest drivers. (280.26)
Also tested on an older card, GeForce 7300 SE, with the latest driver version too, and got the same behavior with the DLLs... but that card can't handle the CRT shader anyway :P
both are running on XP Pro SP3 machines, btw.
User avatar
VileRancour
Postby nikiniki » 2011-9-12 @ 01:04
Great screenshots. It's like playing CGA games on Game Boy.
User avatar
nikiniki
Postby nikiniki » 2011-9-12 @ 21:19
Seriously. I remembered in 80s, I watched a game on the PCjr equiped with a monochrome monitor in the store.
I wonder what it would affect in Tandy/PCjr mode with a mono monitor.
User avatar
nikiniki
Postby nikiniki » 2011-9-12 @ 22:15
It works
You do not have the required permissions to view the files attached to this post.
User avatar
nikiniki
Postby coper1 » 2015-12-29 @ 02:11
it´s great! i´m using your cga_mono option and im playing just like my teenage times. thanks VileRancour
coper1
Postby basic » 2017-5-27 @ 05:30
I fixed this patch, it will patch correctly with DOSBox SVN r4019.
And added paper-white color in CGA/Hercules mode, press F11 to cycle through green, amber, RGB-white, and paper-white.
cga_mono_r4019.diff
Thanks, VileRancour.
Paper-white palette looks like actual white monochrome monitor.
basic
Postby VileRancour » 2017-6-19 @ 22:15
Interesting, how did you derive the paper-white gradient?
The color values look like the 16 steps are tinted (in various directions) away from grey... and according to the 'Paper-White Phosphors' sidebar here, that may actually have some basis in how these monitors are designed. Didn't know that. :)
User avatar
VileRancour
Postby Qbix » 2017-6-21 @ 07:57
just a quick note about the patch.
It's "wrong" to add to 2 different "SHELL_STARTUP_CGA" messages.
Just give them a different a different name and do the selection at the point where they are being printed. (so where the MSG_Get is used)
Water flows down the stream
User avatar
Qbix
DOSBox Author
Previous
Return to DOSBox Patches
Who is online
Users browsing this forum: Shane32 and 2 guests
