First post, by mangomonster
Hi all,
I'm running Mac OS 10.6.8 with Dosbox 0.74
I got Quest for Glory 4 installed and I even installed all the Sierra patches.
None of the keys on my keyboard work except the return key and 'option+return' to go to full screen and back.
I'm pretty sure my keys are mapped wrong. When I type keyb in dosbox, it says "codepage 437 has been loaded".
Dosbox seems to be loading my mapper file from
/Users/mangomonster/Library/Preferences/mapper-0.74.map
So I imagine that's where the problem is... but I can't seem to find any good info on this after googling for an hour. Can anyone help me?
Thanks!
Reply 2 of 16, by mangomonster
Didn't seem to help. It's set as US English. I'm using the buit in keyboard on my Macbook Pro. I've tried the keymapper in Dosbox and it doesn't seem to help.
Reply 4 of 16, by mangomonster
English... I've never used another language.
Reply 5 of 16, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Sigh... I'm NOT talking about the layout that is set on OSX, I'm talking about the actual hardware layout.
Anyway, when you launch dosbox, do the keys work and they just don't work in the game?
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 6 of 16, by mangomonster
I figured that's what you meant after I sent that last message, 🤣.
Correct, the keys work fine in DOS. It's only when using the game that everything goes haywire...
Reply 8 of 16, by mangomonster
hmm, maybe I'll do a fresh download and install. Thx
Reply 9 of 16, by mangomonster
Nope, just installed the QFG4 CD-rom version and I still have the same problem. Enter works.. but all the other keys don't work right in the program. Same problem I had with the Disk version of the game. I've even tried running the programs through Boxer and it's the same.... =/
Reply 10 of 16, by Gamecollector
Try to change usescancodes= value.
Reply 11 of 16, by robertmo
have you got joystick connected? or forced dosbox to emulate one?
Reply 12 of 16, by mangomonster
no Joystick connected and dosbox is not emulating one....
Reply 13 of 16, by mangomonster
@Gamecollector: Where do I change that value?
Reply 14 of 16, by Gamecollector
[sdl] section of the .conf file.
Reply 15 of 16, by mangomonster
Are you talking about the DOSBox 0.74 Preferences file under my username/library/preferences folder? If so, I changed it there from =true to =false and still no change
Reply 16 of 16, by mangomonster
I did a fresh install of Dosbox AND QFG4, this time the CD-Rom version on my Hackintosh running Snow Leopard 10.6.8 and same problem... completely different computer, however it's running the same OS version.
