First post, by snorg
Hello
I inherited a *really* tiny 486 system, not sure who the maker was as its not labelled. It is a 1U box, very cramped, only has enough room for a 3.5" HD and a 1.44mb floppy. If the HD was removed and replaced with a compact flash adapter, there is a 16 bit ISA slot that might accomodate a Soundblaster with a right-angle adapter.
RAM wise, it is not too bad, has 16MB. I powered it up but couldn't get very far with it, since it uses AT style keyboard adapter and not the PS/2 mini DIN adapter. CPU is a 486 DX2 66. No onboard sound, but there is onboard video. I have no clue what the video chip is since I couldn't get past the "halt on no keyboard" error to get into the BIOS or boot it fully. HD is a Quantum fireball but no idea as to size. Maybe a gig.
I was thinking this might be a fun little box to fart around with, but I might need to use a laptop HD and maybe get one of those floppies with a CF adapter underneath for file transfer. I have a parallel port ethernet adapter so I'm good there.
What type of VGA chip do you suppose it has? I would like to put a soundboard in but no clue where I'd find the ISA riser.
Any ideas what all I could do with this system to trick it out a bit more?
I know its not going to be much of a games machine, especially since I have no idea of the provenance of the VGA adapter, and the difficulty I might have putting a soundboard in.
