Old school small form factor (1U) 486 - ideas?
First post, by snorg
Hello
I inherited a *really* tiny 486 system, not sure who the maker was as its not labelled. It is a 1U box, very cramped, only has enough room for a 3.5" HD and a 1.44mb floppy. If the HD was removed and replaced with a compact flash adapter, there is a 16 bit ISA slot that might accomodate a Soundblaster with a right-angle adapter.
RAM wise, it is not too bad, has 16MB. I powered it up but couldn't get very far with it, since it uses AT style keyboard adapter and not the PS/2 mini DIN adapter. CPU is a 486 DX2 66. No onboard sound, but there is onboard video. I have no clue what the video chip is since I couldn't get past the "halt on no keyboard" error to get into the BIOS or boot it fully. HD is a Quantum fireball but no idea as to size. Maybe a gig.
I was thinking this might be a fun little box to fart around with, but I might need to use a laptop HD and maybe get one of those floppies with a CF adapter underneath for file transfer. I have a parallel port ethernet adapter so I'm good there.
What type of VGA chip do you suppose it has? I would like to put a soundboard in but no clue where I'd find the ISA riser.
Any ideas what all I could do with this system to trick it out a bit more?
I know its not going to be much of a games machine, especially since I have no idea of the provenance of the VGA adapter, and the difficulty I might have putting a soundboard in.
Reply 1 of 27, by Mau1wurf1977
Do you have a picture?
It might be that little machine from Unisys. Does it have Ethernet and PS/2 ports at the back?
They should come with the ISA riser. I had an AWE64 in my machine because of the short lengh.
My YouTube channel
Reply 2 of 27, by snorg
You are probably right, this used to be my cousins and he woud always pick up all kinds of wierd corporate gear. Once got a quad 486 made by Acer (think it was Acerframe 3000 mp) but had to sell it to pay some bills, sadly. It was a beast.
It has ps/2 ports on back, parallel and vga, also serial. It probably had an ISA riser at one point, but I think he may have yanked it to get the HD in there. There really isn't anywhere else to put it.
I can post a pic, but not now I am pretty beat.
Reply 3 of 27, by snorg
Here are pics of the mystery PC:
Reply 4 of 27, by sliderider
Geez, that's a 1U case? I have hard drives mounted in cases that look like that.
Reply 5 of 27, by snorg
Pretty sure it is a 1U - its only about an inch high. Not much room, just enough for 1 16bit ISA card mounted sideways. I am going to have a hell of a time finding a compatible riser for it. Then I have to either sacrifice the HD and go with compact flash or ditch the floppy and try and cram a laptop HD, CF card and low profile floppy in the 3.5" bay.
Software installation will be problematic since there is no way to hook up a CD-ROM to this thing. Unless I route the cables outside the box and set it on top, and just use it temporarily to get the OS on (I was planning on installing OS/2, and making floppy images for OS/2 off the CD is a nightmare).
It is a neat little box. I really didn't expect it to have that much RAM, that was a good bit of fortune. 16mb is really useful for 95/98 or OS/2. Wish I knew what sort of VGA chip it has (please Tseng labs - I hope).
What was integrated VGA from this era like? I'm trying not to get overly optimistic and there is no way to replace the VGA.
Reply 6 of 27, by sliderider
It must be bigger than it appears in the photos because I swear an Apple Xserve is a lot bigger than that and it's supposed be in a 1U case, or at least Apple's idea of a 1U case.
Reply 7 of 27, by snorg
Maybe I'm mistaken, then, and its not a true 1U box. But its no more than 1.5" high, so whatever else it is it definitely qualifies as small form factor.
Reply 8 of 27, by Mau1wurf1977
That looks quite like the Unisys I had, but without Ethernet. What does it look like from the front?
EDIT:
Found some pics from my 486 (unfortunately sold it). NEVER sell your Retro stuff 😢
Reply 9 of 27, by snorg
It doesn't look like that. Its a very plain beige front with no badging or anything.
Reply 10 of 27, by GXL750
The onboard video is probably 1mb. My guess would be some variety of Cirrus or Chips and Tech.
It looks like it could be a fun project computer but actual useful value is probably low. I'd just install Windows 3.1 or Win95 and use the thing for old games. Systems of that sort were typically purchased with a specific purpose in mind. You could install an older copy of MS Office, use the box for documents and see just how productive you can be when you're not able to be distracted with internet, modern games and MP3s.
If you have any thrift shops nearby, I would check them regularly. I know around here, thrift shops are the best bet for finding vintage PC parts if you're not interested in buying off eBay or elsewhere online.
Reply 11 of 27, by snorg
Yeah, I just thought it might be something fun to futz around with but wasn't going to spend a ton of $$$ on parts for it. Its a shame there is no riser for it, or that it isn't tall enough for a 2 slot riser. And given how much integrated graphics suck even today (compared to discrete) performance will probably be so-so.
I ended up having to order an AT keyboard adapter because all the keyboards I have are PS/2 or USB. I thought I had one but must have ditched it. Does anyone make ISA usb boards even? I'm guessing no.
A couple USB ports might solve a couple problems but I'm not sure theres enough bandwidth on an ISA slot to support USB 1.0 let alone 2.0.
Reply 12 of 27, by GXL750
I've never seen a USB ISA card. If you were to go out of your way to make the machine more expandable, I would find an ISA PCMCIA card which, in theory, might allow you to install a usb and a wireless card.
As for performance, I would expect it to be lower than the majority of 486 rigs showcased here but above the majority of 386 systems.
Reply 13 of 27, by snorg
Problem with that is drivers. Most likely wouldn't be supported under 95.
I think this machine could probably handle 98, but I don't think I have a 98 license anywhere. I doubt OS/2 would support USB.
I'm not super worried about wireless, I have an ethernet adapter and there is always sneakernet.
I guess if I wanted to get the most use out of this, my main concerns are getting a soundcard in there without losing the HD, or finding a way to wedge in a laptop drive and a CF or SD card adapter so I can move files over from my modern PC and not worry about losing the floppy.
Might be nice to upgrade the RAM but 16mb is useable w/ 95 (probably 98 too) and OS/2 Warp. The OS/2 box I had didn't have more than 12 or 16MB back when I had it and ran ok.
Reply 14 of 27, by snorg
And yeah, I'm not really expecting this thing to be a barn burner performance-wise but it might make a decent retro gaming system if I stick to non 3d games (no quake, but maybe Doom or Tie Fighter)
Trying to expand an old system (especially a limited form factor like this one) really makes you appreciate how much integration there is in modern systems that we take for granted.
Reply 15 of 27, by snorg
So I just had a great idea as far as getting software on this thing ( since I don't want to make 20 some floppies for OS/2 from the CD)
I should be able to temporarily hook up a IDE cdrom as a slave to the HD, or hook up a scsi cdrom to a scsi card. IDE probably makes more sense, I don't have to bother hunting down a scsi cdrom.
Too bad I can't get a sound card/scsi board combo, that would solve the no sound and give me some external expansion.
Reply 16 of 27, by Mau1wurf1977
I had this method to install W95B on my 486DX4-100 Unisys machine: Iomega Zip 100 Parallel. I had the W95 installation files on a ZIP Disk and a simple Boot Floppy with Iomega's GUEST.EXE.
My YouTube channel
Reply 17 of 27, by snorg
I used to have a zip 100 parallel port drive. I'm not sure if I still do. If I do, the power adapter for it has probably gone AWOL.
Reply 18 of 27, by Tetrium
Iirc the parallel external ZIP drives (the large blue ones) use a 12v PSU which should be relatively easy to replace. I'll go check mine now and edit this post...
Edit:Correction, it's 5v (and 1A), which is still pretty much standard. The only thing to watch out for is that the plug actually fits as there are several different sizes 😉
My retro rigs (old topic)
Report spammers here!
Reply 19 of 27, by luckybob
Actually, they do:
http://www.ebay.com/itm/150674259803
And if you want a soundblaster:
http://www.ebay.com/itm/370525522285
Only problem with the sound blaster is it doesnt have EXTERNAL scsi connection, but you might be able to jury-rig one.
