First post, by CapnCrunch53
Hey guys, I've been setting up my newly-acquired 386 system for the past few hours, and just finished. I went to play SimTower in Windows 3.11, and it tells me it cannot run without TrueType and quits. Apparently TrueType is disabled at 256 colors and below. My video card is an ISA Tseng ET4000AX, and it will not load windows at color settings higher than 256 colors. If I select 32768 or 65536, it says I can't do that and kicks me back to DOS.
Now based on the second-to-last comment in this thread VGA VLB Tseng STB ET4000 W32P video card, quick test, as well as some hinting in the driver readme, I think that the ET4000 needs at least 1MB of memory to run higher than 256 colors. Mine has 512KB according to the ebay seller I purchased it from. However, looking at the card, is the vertical row of sockets on the left where additional RAM goes? If so, it looks like it has 4 256KB chips, right? If so, are they maybe in the wrong sockets for it to detect all of them? I am completely new to this so please forgive me for sounding stupid and educate me!
So basically to sum up, my questions are:
1. Can the ET4000AX run higher than 256 colors with 1MB of memory, and
2. Judging from my picture, how much memory is installed, and does it appear that anything is configured incorrectly?
Thanks a ton guys, like I said I'm a total noob to this.
Specs:
25MHz Intel i386DX-25
Cyrix FasMath Coprocessor
8x1MB RAM
Tseng ET4000AX ISA
Creative Sound Blaster Pro 2.0 CT1690
341MB Western Digital Caviar 2340
MS-DOS 6.22 / Windows for Workgroups 3.11
Pictures (these are the seller's pics, not mine.) Warning, these pics are HUGE!
PCs, Macs, old and new... too much stuff.
Reply 1 of 9, by mwdmeyer
IMHO it looks like everything is configured correctly and your card is simply a 512k model, and yes I believe 1mb should allow more colours but I'm not 100% sure on this.
Reply 2 of 9, by DonutKing
Memory chip capacity is measured in bits rather than bytes. Those chips are 4C4256 chips, which means they are 4 bits wide with 256 kilobits of memory on each bit of width. 8 kilobits makes one kilobyte, so each chip is half a kilobit total - so 128 kilobytes.
You have 4 of these making a total of 512 kilobytes.
You need more memory to run in greater than 256 colours. If you can get some DIP 256x4 memory chips with 80ns or less access time you should be able to use the higher colour modes.
Reply 3 of 9, by CapnCrunch53
Ah that makes perfect sense. And I bet the "-8" means 80ns access time too. Thanks guys, told you I was a noob 🤣.
Looks like I'm gonna be ordering a few of those puppies. Any online suppliers you guys would recommend?
Reply 4 of 9, by Great Hierophant
Theoretically you can run 640x480x16 or even 800x800x16 with 1MB of frame buffer, but you can only do 640x480x8 and 800x600x8 with 512KB. However, even if the chip does support these resolutions, an ISA card without the ability to use double buffering, the results may not be particularly fluid.
Why are there three sockets for EPROM? Usually you find one EPROM, which has an 8-bit bus width. I suppose they could have put a second EPROM to enable a 16-bit bus width. This would be useful in 286 machines, as 386 machines could shadow the ROM to RAM and speed it up alot. But only 32KB is needed, and it seems like all the sockets expect 32KB devices. 32KB x 2 is 64KB. I wonder what the third EPROM is supposed to be for in that case.
Reply 5 of 9, by SarahWalker
The RAMDAC looks to be a TR9C1710, which is a 256-colour only DAC. So that card can't show more than 256 colours regardless of how much memory is fitted.
Reply 6 of 9, by elianda
SarahWalker is right, you need a ET4000 with Trucolor DAC and your card has only a 256 color DAC.
Youtube Channel
Reply 7 of 9, by CapnCrunch53
Well crap, that sucks. I already bought the memory chips too. Oh well, guess I'll just run SimTower on my Pentium 3 for now. Thanks a lot for the info guys.
Reply 8 of 9, by idspispopd
Are you sure that's the reason? AFAIR you need to install a (any) printer driver to be able to use TrueType fonts in Windows 3.1x.
The Limitation to 15/16 bit color doesn't make much sense. (It would make sense for anti-aliasing which Windows 3.1x did not have yet.)
Reply 9 of 9, by CapnCrunch53
So it turns out, I'm a massive idiot. I installed a printer driver like you suggested idspispopd, and then realized I had to install a a TrueType font manually. I'm not sure if I could do it before I installed the printer driver because it never occurred to me. Boy do I feel dumb.
SimTower runs now, although it's pretty slow. The Pentium MMX rig I'm building should handle it fine though, and in the meantime it's still playable. Thanks for the advice!
