Reply 20 of 2421, by Jorpho
- l33t++
wrote:I am releasing the latest revision (build 1392) of the DOS source code library. This fixes some issues I found while testing the […]
I am releasing the latest revision (build 1392) of the DOS source code library. This fixes some issues I found while testing the source code against some new scenarios and while filming the code running on various hardware (I will be releasing a video when I have time on the 8042 keyboard controller and how it works, and what the DOS source code library does to interact with it).
http://jon.nerdgrounds.com/dosbox-x/1392/
Additions to the library:
- DOS "flavor" detection. The library is able to detect MS-DOS vs FreeDOS
- If FreeDOS, the code is able to obtain the kernel revision and revision string
- VGA library now contains detection for Amstrad 640x200x16 graphics mode and corresponding test program.Bug fixes: 8042 keyboard library/test program
- The PS/2 mouse main menu no longer reprints the menu text on EVERY keypress. But if it scrolls off-screen, you can force a reprint by pressing "space"
- Exiting the PS/2 mouse menu now forces the 8042 to drain it's output. This resolves issues with an unresponsive keyboard when exiting the PS/2 mouse menu.Bug fixes: DOS library
- Fixed 16-bit builds not detecting HIMEM.SYS when HIMEM.SYS is obviously loaded in memory.
- DOSBox and VirtualBox detection code seems to cause mystery GPF fault and DOS32a brainfuck when 32-bit builds are run under FreeDOS 1.0 (kernel version 0.0.36), code has been updated NOT to scan if that particular FreeDOS kernel is detected. FreeDOS 1.1 doesn't have this problem.Bug fixes: Sound Blaster library
- The latest changes to the DOS library made building the 16-bit "compact" memory model version of the TEST program impossible (more than 64KB of code), the makefile has been modified to not compile the dos86c build.Bug fixes: VGA library
- Direct linking within the makefile caused Watcom to produce a 386 32-bit binary that did NOT link properly to the C runtime and was effectively unusable. Rewritten to use wlink instead, like all other projects. FIXED.Cleanup:
- All make files have been cleaned up and dependencies rewritten in a cleaner manner.Additional code checked:
- Under "misc" the hexmem program (a program for browsing the contents of your computer's memory) has been updated to use the LLMEM library. This means that if you have a recent processor and your motherboard supports 4GB of RAM or more, you can look at memory at or above the 4GB memory boundary from DOS! The code has also been updated to enforce physical memory limits reported by CPUID to avoid crashes, as some CPUs (especially Intel Atom CPUs) will trigger a fault if you attempt to read beyond the limit. (obviously, you must be running in pure DOS mode with or without EMM386.EXE as such techniques are invalid within a Windows DOS box).Have fun!
I'm confused. Are you running FreeDOS in DOSBox, or the other way around?
