First post, by bearlindo
HI dosbox works perfectly in a small screen on my computer but when i turn inte full screen i can hear the game goes on in the background but the picture just freeze. Anyone ho can have an idea what the problem is.
change output in dosbox settings. The config file tells you which settings are possible. You might alos need to update your graphics drivers.
Where exactly in the config file
Where it says output=
output=surface
Thats what it says
Yes, that's the default, read what is written above it and change it accordingly and update your graphics card drivers.
output: What video system to use for output.
# Possible values: surface, overlay, opengl, openglnb, ddraw.
how do i know what oof them to choose
C'mon... Try...
I would recommend openglnb. Same as opengl, but no filtering.
I would recommend direct3d since it plays nice with aero, coupled with scale2x forced
There is no direct3d with normal builds 😉
Try disabling Full Screen Double Buffer if enabled or vice-versa.
I would use ddraw for ATi/AMD cards and OpenGLnb for nVidia ones.
Just do a quick test and keep trying.
