First post, by bearlindo
HI dosbox works perfectly in a small screen on my computer but when i turn inte full screen i can hear the game goes on in the background but the picture just freeze. Anyone ho can have an idea what the problem is.
Reply 1 of 12, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
change output in dosbox settings. The config file tells you which settings are possible. You might alos need to update your graphics drivers.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 12, by bearlindo
Where exactly in the config file
Reply 4 of 12, by bearlindo
output=surface
Thats what it says
Reply 5 of 12, by Dominus
DOSBox Moderator
Yes, that's the default, read what is written above it and change it accordingly and update your graphics card drivers.
Reply 6 of 12, by bearlindo
output: What video system to use for output.
# Possible values: surface, overlay, opengl, openglnb, ddraw.
how do i know what oof them to choose
Reply 8 of 12, by Teppic
I would recommend openglnb. Same as opengl, but no filtering.
My AdLib recordings
Reply 9 of 12, by leileilol
I would recommend direct3d since it plays nice with aero, coupled with scale2x forced
long live PCem
FUCK "AI"
Reply 11 of 12, by filipetolhuizen
Try disabling Full Screen Double Buffer if enabled or vice-versa.
Reply 12 of 12, by eL_PuSHeR
I would use ddraw for ATi/AMD cards and OpenGLnb for nVidia ones.
Just do a quick test and keep trying.
