First post, by persika
I have tried Dosbox, and it works graet in most may.
But i have a problem with swedish character åäö.
From keabord to screen it works fine, but from filesystem to screen it will be wrong, and also when a program tries to open a file with a file name containing swedish character (åäö).
The command DIR also report filename wrongly.
pls, take a look at attached print screen:
What is the reason, do I have not correct settings ?
I use Dosbox 0.74 on Windows 7.
