First post, by persika
I have tried Dosbox, and it works graet in most may.
But i have a problem with swedish character åäö.
From keabord to screen it works fine, but from filesystem to screen it will be wrong, and also when a program tries to open a file with a file name containing swedish character (åäö).
The command DIR also report filename wrongly.
pls, take a look at attached print screen:
What is the reason, do I have not correct settings ?
I use Dosbox 0.74 on Windows 7.
    33.9 KiB
Reply 2 of 14, by Gamecollector
DOSBox use default CP 437 for the file system.
And currently there is no way to change the CP in DOSBox. (No DISPLAY.SYS loading, nlsfunc or chcp).
Reply 3 of 14, by robertmo
I noticed it also doesn't work when in booted dos. I mean i cannot even type non us characters, although display.sys, mode, keyboard.sys was loaded fine from config/autoexec. Am I doing something wrong or it should be like that? Also as i don't remember does it mean it won't work in booted windows9x too (don't remember now and right now i only have us installed)?
Reply 4 of 14, by wd
Rank DOSBox Author
DOSBox Author
The first, this is fully a software-only problem then (char translation to/from the disk image which is done by dos/dos device drivers).
Reply 5 of 14, by robertmo
you can check it yourself
it works on real computer but doesn't in dosbox
all the characters I typed at the end should be polish letters, but are not
and z should be swapped with y, but is not
c:\>ver
MS-DOS Version 6.20
    5.46 KiB
Reply 6 of 14, by Gamecollector
Err, Robertmo, you forgot the country= command in the config.sys.
Read this.
Reply 9 of 14, by robertmo
it looks codepage 852 is working as files are displayed with foreign letters and also i can type them with alt 224 for example.
Also it looks all keyboard layouts using that codepage (852) doesn't work in dosbox with booted dos.
Reply 10 of 14, by Fullscreen
Dosbox emulates MS-DOS. MS-DOS 6.x and below only allows ASCII filenames (so no åäö).
MS-DOS 6.x functionality:
* Treat file names stored on the disc as a string and print the string out on the screen without any character set conversions.
* Generate an error message if you try to create a file or directory with a name containing non-ASCII characters.
* Generate an error message if you try to access a file or directory with a name containing non-ASCII characters. A different OS (e.g. PC-DOS) is needed to create the file in the first place.
Dosbox appears to emulate the MS-DOS 6.x behaviour perfectly (see image below), so I assume that there is no bug.
Reply 11 of 14, by Joey_sw
theres might be problem in how dosbox communicates the non-ascii file names to host OS too, IF this were done by mounting directories and not disk-images.
i've made a batch file to creates 128 files each using a character > ALT+0127
Dosbox 0.74 (plain), under winXp English (CP 1252), only 5 files were created on mounted directory.
using winxp NTVDM, only 117 were created.
using real dos this should creates all 128 files, but i doubt Windows could actually read them.
    ascii.zip
    632 Bytes
    314 downloads
    contain ascii.bat
    please run on temporary directory that you could easily delete
-fffuuu
Reply 12 of 14, by robertmo
using real dos 6.20 on real computer it creates 109 files (same as using dos 6.20 booted in dosbox) using default English codepage. For example using polish codepage in dos on real computer it creates only 88 files.
Reply 13 of 14, by Qbix
Rank DOSBox Author
DOSBox Author
DOSBox rejects the creation of files that have names that look like random memory. This is to prevent DOSBox from flooding the harddrive with odd files incase the emulation goes haywire. It is one of the oldest sanity checks in the DOSBox emulated DOS.
Water flows down the stream
