First post, by 3803
What do you guys think?
Just trying to figure out how long I will need to wait before such hardware will be on the market 😀
Reply 1 of 16, by Qbix
Rank DOSBox Author
DOSBox Author
hehe. Well totally depends on the game you want to run.
some games can be run on full framerate.
Water flows down the stream
Reply 2 of 16, by Jackal
OK for example Doom2. I have PIII800 and it runs unplayable. Wich cpu i need to run ... i will have P4 3.06 ghz is it adequate ?
Reply 4 of 16, by icemann
Why run Doom2 under dosbox anyway? It runs 100% under any OS with the sourceports (legacy, jdoom, boom etc).
Two stones, two crosses, the rest is just icing. - 7th Guest
Reply 5 of 16, by Jackal
Yes, but not under WinXP. 🙁
Reply 6 of 16, by jurgen
Have a look at Vavoom or Prboom (please use Google to find out the exact url) ;these should work under XP ....
J.
Reply 7 of 16, by Jackal
OK thx a lot !! And doom 1 ? 😀)))
Reply 8 of 16, by jurgen
It should also run under prboom/vavoom , note that also the 'heretic' wad files work with vavoom,
J.
Reply 9 of 16, by Snover
The idea is that this is a PC/DOS emulator and therefore any program written for DOS will eventually work in it, regardless of whether or not there is a source port. Yeesh. 😒
Yes, it’s my fault.
Reply 10 of 16, by icemann
Doomsday is also another great one. Runs Doom,Doom2, Heretic and Hexen in super fancy graphics. Runs under any OS to my knowledge.
Reply 11 of 16, by Jackal
Thank you. It works perfectly !! Now i can play doom with cross and with mouse 😀)
Reply 12 of 16, by oneirotekt
Doom Legacy works fine under XP as well.
Reply 13 of 16, by icemann
I`d recommend download the Doom64 TC that only works in Doomsday on a side note, if you`d like to see Doom looking even fancier than it already does under Jdoom. Best TC I`ve played in months.
Reply 14 of 16, by Darkfalz
Running DOOM under DOSBox with 12500 cycles (about the highest I can go without sound cracking up) on my P4 3 GHz its like playing it on a 486 33 MHz, ie about 20 fps.
Reply 15 of 16, by Predator
and what about viewing demos (game recordings) with the original doom ?
Don't be so hard
Reply 16 of 16, by AdamW
predator: use prboom - compatibility with original .exe demos is very high, virtually all will play.
adamw
