First post, by 3803
What do you guys think?
Just trying to figure out how long I will need to wait before such hardware will be on the market 😀
hehe. Well totally depends on the game you want to run.
some games can be run on full framerate.
Water flows down the stream
OK for example Doom2. I have PIII800 and it runs unplayable. Wich cpu i need to run ... i will have P4 3.06 ghz is it adequate ?
probably.
Why run Doom2 under dosbox anyway? It runs 100% under any OS with the sourceports (legacy, jdoom, boom etc).
Two stones, two crosses, the rest is just icing. - 7th Guest
Yes, but not under WinXP. 🙁
Have a look at Vavoom or Prboom (please use Google to find out the exact url) ;these should work under XP ....
J.
OK thx a lot !! And doom 1 ? 😀)))
It should also run under prboom/vavoom , note that also the 'heretic' wad files work with vavoom,
J.
The idea is that this is a PC/DOS emulator and therefore any program written for DOS will eventually work in it, regardless of whether or not there is a source port. Yeesh. 😒
Yes, it’s my fault.
Doomsday is also another great one. Runs Doom,Doom2, Heretic and Hexen in super fancy graphics. Runs under any OS to my knowledge.
Thank you. It works perfectly !! Now i can play doom with cross and with mouse 😀)
Doom Legacy works fine under XP as well.
I`d recommend download the Doom64 TC that only works in Doomsday on a side note, if you`d like to see Doom looking even fancier than it already does under Jdoom. Best TC I`ve played in months.
Running DOOM under DOSBox with 12500 cycles (about the highest I can go without sound cracking up) on my P4 3 GHz its like playing it on a 486 33 MHz, ie about 20 fps.
and what about viewing demos (game recordings) with the original doom ?
Don't be so hard
predator: use prboom - compatibility with original .exe demos is very high, virtually all will play.
adamw
