Windows 3.1 in 256 colours
Developer's Forum, for discussion of bugs, code, and other developmental aspects of DOSBox.
Re: Windows 3.1 in 256 colours
Postby Dominus » 2011-5-22 @ 17:53
Do you mean the sb drivers linked to in the windows 3.x guide for dosbox? Because those used to work, if those do not work anymore I need to know that.
The screen problem does not affect everyone, btw. Works fine for me on OS X (that has another bug though with that many colors).
User avatar
Dominus
DOSBox Moderator
Postby arromdee3 » 2011-5-23 @ 03:09
When I downloaded dosbox it didn't come with a Windows 3.x guide. There doesn't seem to be a Windows 3.x guide at the start of this thread either.
The drivers I used were the ones that you can find by going to http://support.creative.com/Products/pr ... nd+Blaster and selecting "Others" and "Sound Blaster 16" (under "archived products"), then clicking "Next". When you manually select Windows 3x driver, the result contains two pages with SB16 drivers on them: "Sound Blaster 16/SB32/AWE32 Basic Disk for DOS/Windows 3.1 Installation" and "Windows 3.1x drivers for the Sound Blaster ISA 16/32/64 cards". The former worked for me, the latter did not (it didn't even put anything in control panel/drivers, while the former did).
arromdee3
Postby Dominus » 2011-5-23 @ 05:06
This forum has a dosbox guides sub forum which has this guide.
User avatar
Dominus
DOSBox Moderator
Postby wd » 2011-5-23 @ 06:39
This is just getting way too stupid now. Don't run win3x, just don't.
wd
DOSBox Author
Postby BastetFurry » 2012-7-08 @ 09:49
@wd:
Why? It works like a charme.
You just need more DOS-foo than the average Win-User (Post 9x) to get it running flawlessly.
I do a 3.11 install on DOSBox while still half asleep waiting for my coffee machine to make me some "Potion of Resurection". ;)
@arromdee3:
If you want the SB drivers inside Win3.x you need to run the DOS installer... sounds weird, but the Creative DOS installer detects Windows and places the drivers inside it and edits the win.ini for you.
I am not at home currently and cant access my machine trough NX because its off, otherwise i would have uploaded the driver for you, drivers are free for distribution anyways. And while i am at it i would upload WinG, Win32s and Intel Indeo too.
BTW, i use that setup to play Die Total Verrückte Rally and Battle Isle 3 from BlueByte.
Both won't run on modern Windowses and not even in WINE, but they run flawlessly on DOSBox with Windows 3.11.
User avatar
BastetFurry
Postby Dominus » 2012-7-08 @ 10:00
You just need to follow the guide and you are set ;)
But wd replied to the op who's better off not running w3.11 ;) also no need to revive that old threads for writing stuff that is in the guide ;)
User avatar
Dominus
DOSBox Moderator
Postby BastetFurry » 2012-7-08 @ 10:14
Oh, didnt saw that, sorry for thread necromancing. :)
User avatar
BastetFurry
Postby Dominus » 2012-7-08 @ 10:58
Feel free to add anything to the guide thread if you find something missing ;)
User avatar
Dominus
DOSBox Moderator
Postby trlkly » 2012-10-03 @ 19:45
Since there is a guide thread with much better detail, is this thread even necessary to be pinned anymore?
trlkly
Postby Dominus » 2012-10-03 @ 19:48
Please don't tell us you saved your first post for this...
User avatar
Dominus
DOSBox Moderator
Postby jal » 2012-10-04 @ 16:59
Dominus wrote:Please don't tell us you saved your first post for this...
We all gotta start somewhere...
JAL
User avatar
jal
Postby videogamer555 » 2017-1-14 @ 04:23
canadacow wrote:CVS 12-22-2004
Includes almost complete emulation of video emulation needed for the S3 Windows 3.1 driver. There are still some bugs remaining but the interface is usable and stable
Following link is the driver needed, S3 864 v1.41B5
864141b5.zip
http://www.winsite.com/bin/Info?4009
I've only tested 640x480 and 800x600 in 256 colors using SF or LF modes.
You may have to skip the Windows splash screen by running, "win /b".
Broken link. Where can I down the Windows 3.1 256 color driver now?
videogamer555
Postby Jorpho » 2017-1-14 @ 05:00
User avatar
Jorpho
Postby Dominus » 2017-1-14 @ 08:18
Necroposting annoys me, especially when this last page already deals with that. So locked
User avatar
Dominus
DOSBox Moderator
Previous
Return to DOSBox Development
Who is online
Users browsing this forum: Google [Bot] and 1 guest
