SimCity 2000 problem
First post, by MarkoUu
So i'm quite new to DosBox but i have been searching a lot for this problem.
I have Windows 7 64bit and DosBox 0.74
I installed SimCity 2000 but DosBox said that "The video card was not found."
So i opened the simcity 2000 setup and changed the Video card to "ATI VGA wonders"
After that, the game "starts" but i can only hear the music, and if i click randomly around i can hear that the game is running, but i cant see anything.
My video card is Ati Radeon 4870X2 and soundcard is SoundBlaster Xtrememusic.
Is there any solution?
Reply 1 of 11, by MarkoUu
And i tried other video card settings from the SimCity2000 setup, but none of what i tried worked
Reply 2 of 11, by TeaRex
Have you tried changing the video card emulated by DOSBox?
If you're on Windows, go to start->dosbox->options and change the option for the emulated video card.
tearex
Reply 3 of 11, by MarkoUu
How do i actaully change that? The Options opens as a notepad and I dont know what to change from there
Reply 4 of 11, by MarkoUu
Or is the option for "machine" ?
At the moment the "machine" is svga_s3
Other options for that are: hercules, cga, tandy, pcjr, ega, vgaonly, svga_s3, svga_et3000, svga_et4000, svga_paradise, vesa_nolfb, vesa_oldvbe.
How do i know which one?
Reply 5 of 11, by TeaRex
Yes that's what I mean.
I don't have your specific game so I don't know which one is right, but you should try the several svga and vesa modes as well as vgaonly.
Also note that this has absolutely nothing to do with your real hardware graphics card model.
tearex
Reply 6 of 11, by ripsaw8080
Rank DOSBox Author
DOSBox Author
The default setting of machine=svga_s3 should work fine if you configure the game for "VESA Super VGA".
Reply 7 of 11, by TeaRex
Especially, if there is any of the machine types that matches one graphics card type which is selectable in the Sim City 2000 setup - that one should work.
EDIT: Better to follow ripsaw's advice, I guess he has the game.
tearex
Reply 8 of 11, by MarkoUu
ripsaw:
I tried SimCity 2000 with "Vesa Super Vga" and the machine as svga_s3 but it just says "video card not found bla bla bla"
EDIT: yeah sorry i messed up. Thanks ripsaw, it totally works now.
Reply 9 of 11, by luckybob
simcity 2000 will run fine in windows 7 x64. I know, I've done it. the INSTALLER is 16 bit and cant cope. If you legit own 2000, you can find a modified installer if you look carefully online. OR send me a PM if you cant find it on your own.
Reply 10 of 11, by Jorpho
There are multiple versions of SimCity 2000, including a 16-bit Windows version, a 32-bit Windows version (I think), and a DOS version. The 16-bit Windows version and the DOS version cannot possibly ever run under Windows 7 x64 without DOSBox or something similar.
Evidently the OP is trying to run the DOS version in DOSBox. (This is the same version sold by GOG.com, so it certainly can be done.)
Reply 11 of 11, by eL_PuSHeR
[Thread moved to DOSBox Games/Apps. Section]
