Reply 40 of 122, by Perth2008
 - Newbie
Errr, OK ... just thinking about your initial comments (again): is it possible that a new executable coupling your earlier ~2009 code fix (myavp.exe ???) with superior(?) rendering with the soundtrack fix would be a better position to be working forward from?
Just thinking out aloud, not really understanding how one writes code. I assume (which may be misguided) that you can borrow bits from your earlier work before changing rendering system and re-code the code?
Most likely a simple question to ask ... but not so simple in practical terms.
Anyway I'm off to sleep. Cheers,
Perth2008
http://au.gamespot.com/users/Perth2008
