Reply 560 of 760, by Great Hierophant
- l33t
wrote:Can someone explain how the "auto" mode works, is it that it only sets up composite mode for 640x200x2 modes? It doesn't seem to be setting composite mode for "Rad Warrior" which needs it to read the UI details (i.e. score, etc.). Is there any way to set the composite mode via config entries?
Rad Warrior is using a 320x200x4 mode, so you must use the F12 key to get composite video. There is no line in DOSBox's configuration file for it.
