lucky7456969 always has some weird obscure use case for DOSBox. 😜
lucky7456969 wrote:
2) When I am using Acrobat Professional 8 to print out stuff, the printouts look like this, first 3 scanlines are black, then next 3 scanlines are white, then alternately. like a zebra pattern
If it was a real printer, I'd say driver mismatch. If you were using a 9-pin dot matrix printer, with a driver for an 18-pin printer, I'd expect that maybe it would feed too much paper for each pass, giving you the effect you describe.
Printing from whatever SVN build you're using? Who knows.
Is this even a DOSBox question at all? Acrobat Professional 8 is a fairly recent product.
