First post, by lucky7456969
1) Are there any downloadable Epson fx-25 printer fonts available somewhere on the net?
2) When I am using Acrobat Professional 8 to print out stuff, the printouts look like this, first 3 scanlines are black, then next 3 scanlines are white, then alternately. like a zebra pattern
Thanks
Jack
Reply 1 of 6, by eL_PuSHeR
[Thread moved to DOSBox General Section]
Reply 3 of 6, by lucky7456969
Hey, I understood that ordinary version doesn't support printing. That's why I posted my thread in the miscellaneous session
Reply 4 of 6, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Well, then don't let us guess which modification of dosbx you are using and then maybe the author will write something.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 5 of 6, by SquallStrife
lucky7456969 always has some weird obscure use case for DOSBox. 😜
If it was a real printer, I'd say driver mismatch. If you were using a 9-pin dot matrix printer, with a driver for an 18-pin printer, I'd expect that maybe it would feed too much paper for each pass, giving you the effect you describe.
Printing from whatever SVN build you're using? Who knows.
Is this even a DOSBox question at all? Acrobat Professional 8 is a fairly recent product.
Reply 6 of 6, by lucky7456969
I am using MB6
