First post, by SKARDAVNELNATE
I started playing Last Half of Darkness 2 and found a map of the passages but when I examine it instead of displaying on the screen I get the message in the title.
I tried HAL 9000's "Mega Build" however it keeps reporting:
The printer is not ready! Is your printer ready?
Reply 1 of 13, by eL_PuSHeR
Could printer be configured somewhere in the program?
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 13, by red_avatar
Just a few things that puzzle me:
a) There IS no Last Half of Darkness 2 that runs in DOS. Which game are you playing? LHOD2 is a 2005 game.
b) DOS games could never require a printer - most people didn't even have a printer until 1995-1996 and LHOD is a 1989 game. Is the printer really needed to see the map?
Reply 3 of 13, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
parallel1=printer
1+1=10
Reply 4 of 13, by eL_PuSHeR
WRONG. There are just a few titles that will use a printer. Shadows over Riva (third part of Realms of Arkania trilogy) will use it, and it is a ms-dos game. I am pretty sure there are some other RPGs out there (some of them from SSI) that will also use a printer.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 5 of 13, by SKARDAVNELNATE
No, just sound, input device, and processor speed.
While looking for information the remakes keep getting in the way. Here's what HOTU says: "This download contains Part I (freeware) and 2 (which you got after paying $25 registration fee)." I'm playing part 2.
parallel1=printer
It now says printing and that I can resume playing. I set docpath=c:\dos but I still don't get a file out of it.
Reply 6 of 13, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
What does the status window say?
1+1=10
Reply 7 of 13, by SKARDAVNELNATE
Attached a screenshot.
Reply 8 of 13, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Try ctrl+F2 after the game says it has finished printing.
1+1=10
Reply 9 of 13, by SKARDAVNELNATE
Now I've got it. I tried drawing one myself but I wound up with several rooms overlapping. Thanks for your help.
Update: I liked the map I drew better so I corrected the overlapping rooms with the information from the printed map. It turns out a passage that turns left was supposed to turn right.
Reply 10 of 13, by SKARDAVNELNATE
Someone tell LGR I made a map.
Reply 11 of 13, by bloodbat
Veil of Darkness can use a printer.
GeoGolf can use a printer.
Reply 12 of 13, by eL_PuSHeR
Nice work although a bit necroposting.
Reply 13 of 13, by SKARDAVNELNATE
Yes, but it is my own topic I necro'ed and only because something relevant to it had happened in the past month.
BTW, I didn't label the Girl in The Wall. Maybe I should.
