First post, by humanton
Hello,
I appreciate any assistance I may receieve as I am new to using dosbox.
I am currently using D-Fend Reloaded which so far made DosBox easier to use.
I own the CD-Rom to Warcraft 2 and when I install from source media "Original CD" in D-fend, the game installs and I can play it. Then when I go to play it at a later time the program tells me the file is a Windows Executable and DosBox can't play it.
I don't know how to install from original CD and still play it later?
Thank you help.
Reply 1 of 5, by Davros
the first question I would ask is why are you trying to run a windows program in dosbox
(ps: screenshot too small to read the text)
pps: If you want to play warcraft 2 it is a really good idea to run the game
instead of the level editor
Reply 2 of 5, by humanton
It is DOS based as per CDRom and it does play at first when I install it through DosBox but doesn't open again... I have full game play when imported it from the source media on original CD.
I don't know what you mean by map editor as I was attempting to open the game itself not these editor.
Reply 3 of 5, by leileilol
sfxed95.exe is a program that allows you to change the sounds of the units. It is designed for Windows 95.
You're supposed to start War2.exe.
I'll also advise fixed cycles of 35000-50000 due to the scrolling speed issue
Debian's fucked
Reply 4 of 5, by humanton
I am so dumb I didn't notice it was the sound file! I should be able to switch that with the war2.exe then maybe?
Thank you for help.
Reply 5 of 5, by eL_PuSHeR
[Thread moved to DOSBox Games/Apps. Section]
