First post, by subhuman@xgtx
Been wondering this.. Someone here said he had better results with sp2 than with sp3 speedwise. I can use 2000 sp4. but I think I'd have to use wrappers if I want to run XP only apps. I have a Mobile Barton 2500+ clocked at 2.42ghz, and 2 gigs of ddr400 ram.
Reply 1 of 7, by Old Thrashbarg
I've never seen any performance difference whatsoever between SP2 and SP3... and there is no reason there should be any difference, either, because SP3 is essentially just a rollup of updates that'd get installed on a SP2 machine anyway. The few new features/changes are quite minor and really only affect some network security settings and group policy stuff... nothing that you're likely to even encounter on a home machine.
Windows 2000 actually has seen quite a few improvements as of late, with the renewed work on the unofficial SP5. A lot of compatibility issues have been ironed out, so you may not need to play with wrappers as much as you think. I don't know if I'd go so far as to recommend it over XP for day-to-day use, but depending on what you're planning to do with the machine, it may still be an option worth considering.
Reply 2 of 7, by mr_bigmouth_502
I once had a Pentium 4 box that ran quite nicely with just SP2, but I was purposefully keeping it offline due to the potential security vulnerabilities. It slowed down to crap once I installed SP3 and put it online. 😜
Reply 3 of 7, by eL_PuSHeR
I haven't noticed any differences either. I like my software to be updated. So SP3 for me. Yes, I have read elsewhere that SP3 doesn't play fair on some configurations for some reason but I have been lucky so far.
Reply 4 of 7, by sgt76
No difference in speed between SP2 and SP3, at least on your system- which is really well-specced for an XP system. Personally, I would avoid W2000.
Reply 5 of 7, by F2bnp
I think there is a difference, but like eL_PuSHeR said I prefer software to be updated to the latest versions. The difference is mostly noticable in machines with 1GB and less RAM and Pentium 4 machines.
Reply 6 of 7, by SiliconClassics
I think SP3 contains some optimizations for Core processors, so it might actually be a bit faster than SP2 on newer systems. When I installed it on my Core 2 Extreme 3.4GHz system there seemed to be a noticeable speed boost. P4 users might do better to stick with SP2, not sure.
Silicon Classics on: YouTube | Twitter | Google+
Reply 7 of 7, by jwt27
You'll need SP3 in order to run modern programs. Everything compiled with the latest version of Visual C will not run on SP2 and below.
