Reply 200 of 227, by ykhwong
wrote:Re: Munt Reloaded - Development Patch to integrate MUNT library into svn-daum (May 2013) […]
Patch to integrate MUNT library into svn-daum (May 2013)1) Download MUNT 1.2 source. Apply munt-master-savestate.diff
- Add partial limits
- Add mt32ram dump / load1a) Compile as static library
- mt32emu_stat.lib2) Download ykhwong's May 2013 build. Apply daum-savestate.diff
- Removes MUNT files. Treat as external lib
- Copy new MUNT header files
- Run MUNT through MIDI savestate code
- Rework MIDI save / load
--- new features: NRPN
--- bug fixes: controller 79h (RPN), correct MIDI / sysex status, other noticeable problems2a) Add mt32emu_stat.lib to linker
2b) Compile and runNot fully tested. Works rather well so far.
That shouldn't happen. ^^
Wow, thanks. 😀 I will try it.
