First post, by P4R4D0X
While I was browsing the PC/XT/AT MESS topic on Emuversal found this nice fractal software called FRACTINT. The guys over there were comparing the tool emulated inside MESS and DOSBox so I thought I might try it as well. It should be on page 98 and 99 in the topic with some DOSBox talk.
Topic: http://forums.bannister.org/ubbthreads.php?ub … r=76084&page=99
So I went to the official website and grabbed the latest one from their servers: FRACTINT Version 20.04.12
Link: http://www.fractint.org/ftp/current/dos/fract … nt-20.04p12.zip
File: fractint-20.04p12.zip
MD5: 4AA9AC4B5EF3221F87DD3A7FDA079E02
SHA-1: 938ECC5191ED7DF78CAB3AC24EAA475E3F3B1C6F
Extracted the files, reset my DOSBox configuration file for 0.74 and SVN, mounted my test folder and ran FRACTINT. Then I pressed ESC to see main menu and selected the following video mode: IBM 256-Color VGA/MCGA 320x200 256 color
It will render correctly for the first time and you will see the following image. You will get a beep when it's ready.
4.36 KiB
Ok, now press Escape to go back to the text mode main menu then select return to image. This is what you will get...
1.27 KiB
It looks weird, because it should be the same image. Now press space and you will see a preview window in the bottom right corner and a cursor. You can use the mouse to draw the image you are supposed to get.
2.35 KiB
Now there's another thing you can do. Go back to the menu and return to the image to see the white lines again. But this time don't press the space bar instead left click on the screen. You will see a dot lined border. Now move the mouse around but don't click yet, because it will redraw the screen with the correct image. If you do this for a while and you got the patience you can fill the entire screen and clear the white lines as well.
9.94 KiB
Found another thing as well. You can interrupt the rendering of the fractal by pressing Esc and you can select continue calculation to complete the image. Except you get this, or something similar, depending on when you paused the process.
6.01 KiB
Now here's the weird part. I tried to experiment with the machine type and found out that this glitch can be reproduced with vgaonly, svga_s3, svga_paradise, vesa_nolfb and vesa_oldvbe. But the Tseng Labs ones work fine: svga_et3000, and svga_et4000. So yeah, reproducible in DOSBox 0.74 and SVN.
I only found one topic on VOGONS with this tool that has to do with DOSBox.
Link to the topic: Topic 10142
Is this really an video emulation bug or just again a "buggy by design" type software? I don't see anything useful in the debugger either. Here are some logs:
  30619439: EXEC:Parsing command line: FRACTINT.EXE
30619442: EXEC:Execute FRACTINT.EXE 0
30619442: FILES:file open command 0 file FRACTINT.EXE
30619551: FILES:file open command 0 file C:\FRACTI~1.04P\FRACTINT.EXE
30624194: MOUSE:New video is the same as the old
30624282: FPU:8087 only fpu code used esc 3: group 4: subfuntion :1
30821319: FILES:file open command 0 file C:\FRACTI~1.04P\fractint.cfg
31391929: FILES:file open command 0 file C:\FRACTI~1.04P\FRACTINT.EXE
31392054: FILES:file open command 0 file C:\FRACTI~1.04P\FRACTINT.EXE
31392168: FILES:file open command 0 file C:\FRACTI~1.04P\FRACTINT.EXE
31430137: FILES:file open command 0 file C:\FRACTI~1.04P\sstools.ini
31453771: FILES:file open command 0 file C:\FRACTI~1.04P\maps\default.map
31957227: FILES:file open command 0 file EMMXXXX0
31957236: IOCTL:07:Fakes output status is ready for handle 5
31957357: FILES:file open command 0 file EMMXXXX0
31957366: IOCTL:07:Fakes output status is ready for handle 5
31957409: FILES:file open command 0 file EMMXXXX0
31957418: IOCTL:07:Fakes output status is ready for handle 5
31958866: FILES:file open command 2 file TARGPLUS
31959005: INT10:Set Video Mode 3
31959005: MOUSE:New video is the same as the old
31959028: INT10:Function 12:Call 30 (select vertical resolution)
31959142: INT10:Set Video Mode 3
31959142: MOUSE:New video is the same as the old
32098823: VGA:h total 100 end 80 blank (80/98) retrace (85/97)
32098823: VGA:v total 449 end 400 blank (407/442) retrace (412/414)
32098823: VGA:h total 0.03178 (31.47kHz) blank(0.02542/0.03114) retrace(0.02701/0.03082)
32098823: VGA:v total 14.26806 (70.09Hz) blank(12.93341/14.04562) retrace(13.09230/13.15585)
37985741: FILES:file open command 0 file C:\FRACTI~1.04P\fractint.cfg
42408904: INT10:Set Video Mode 13
42408904: VGA:Blinking 0
42511472: VGA:h total 100 end 80 blank (80/98) retrace (84/96)
42511472: VGA:v total 449 end 400 blank (407/442) retrace (412/414)
42511472: VGA:h total 0.03178 (31.47kHz) blank(0.02542/0.03114) retrace(0.02669/0.03051)
42511472: VGA:v total 14.26806 (70.09Hz) blank(12.93347/14.04568) retrace(13.09235/13.15591)
42511472: VGA:Width 320, Height 200, fps 70.086303
42511472: VGA:double width, double height aspect 1.200000
54116175: INT10:Set Video Mode E
54116182: IO:Read from port 03BA
54116259: INT10:Set Video Mode 3
54116259: VGA:Blinking 8
54253919: VGA:h total 100 end 80 blank (80/98) retrace (85/97)
54253919: VGA:v total 449 end 400 blank (407/442) retrace (412/414)
54253919: VGA:h total 0.03178 (31.47kHz) blank(0.02542/0.03114) retrace(0.02701/0.03082)
54253919: VGA:v total 14.26806 (70.09Hz) blank(12.93341/14.04562) retrace(13.09230/13.15585)
54253919: VGA:Width 640, Height 400, fps 70.086592
54253919: VGA:normal width, normal height aspect 1.000000
57371112: IO:Read from port 03BA
57371150: INT10:Set Video Mode E
57371150: VGA:Blinking 0
57371157: IO:Read from port 03BA
57371247: INT10:Set Video Mode 13
57371263: IO:Read from port 03BA
57499398: VGA:h total 100 end 80 blank (80/98) retrace (84/96)
57499398: VGA:v total 449 end 400 blank (407/442) retrace (412/414)
57499398: VGA:h total 0.03178 (31.47kHz) blank(0.02542/0.03114) retrace(0.02669/0.03051)
57499398: VGA:v total 14.26806 (70.09Hz) blank(12.93347/14.04568) retrace(13.09235/13.15591)
57499398: VGA:Width 320, Height 200, fps 70.086303
57499398: VGA:double width, double height aspect 1.200000
