First post, by P4R4D0X
- Member
While I was browsing the PC/XT/AT MESS topic on Emuversal found this nice fractal software called FRACTINT. The guys over there were comparing the tool emulated inside MESS and DOSBox so I thought I might try it as well. It should be on page 98 and 99 in the topic with some DOSBox talk.
Topic: http://forums.bannister.org/ubbthreads.php?ub … r=76084&page=99
So I went to the official website and grabbed the latest one from their servers: FRACTINT Version 20.04.12
Link: http://www.fractint.org/ftp/current/dos/fract … nt-20.04p12.zip
File: fractint-20.04p12.zipMD5: 4AA9AC4B5EF3221F87DD3A7FDA079E02SHA-1: 938ECC5191ED7DF78CAB3AC24EAA475E3F3B1C6F
Extracted the files, reset my DOSBox configuration file for 0.74 and SVN, mounted my test folder and ran FRACTINT. Then I pressed ESC to see main menu and selected the following video mode: IBM 256-Color VGA/MCGA 320x200 256 color
It will render correctly for the first time and you will see the following image. You will get a beep when it's ready.
Ok, now press Escape to go back to the text mode main menu then select return to image. This is what you will get...
It looks weird, because it should be the same image. Now press space and you will see a preview window in the bottom right corner and a cursor. You can use the mouse to draw the image you are supposed to get.
Now there's another thing you can do. Go back to the menu and return to the image to see the white lines again. But this time don't press the space bar instead left click on the screen. You will see a dot lined border. Now move the mouse around but don't click yet, because it will redraw the screen with the correct image. If you do this for a while and you got the patience you can fill the entire screen and clear the white lines as well.
Found another thing as well. You can interrupt the rendering of the fractal by pressing Esc and you can select continue calculation to complete the image. Except you get this, or something similar, depending on when you paused the process.
Now here's the weird part. I tried to experiment with the machine type and found out that this glitch can be reproduced with vgaonly, svga_s3, svga_paradise, vesa_nolfb and vesa_oldvbe. But the Tseng Labs ones work fine: svga_et3000, and svga_et4000. So yeah, reproducible in DOSBox 0.74 and SVN.
I only found one topic on VOGONS with this tool that has to do with DOSBox.
Link to the topic: Topic 10142
Is this really an video emulation bug or just again a "buggy by design" type software? I don't see anything useful in the debugger either. Here are some logs:
30619439: EXEC:Parsing command line: FRACTINT.EXE30619442: EXEC:Execute FRACTINT.EXE 030619442: FILES:file open command 0 file FRACTINT.EXE30619551: FILES:file open command 0 file C:\FRACTI~1.04P\FRACTINT.EXE30624194: MOUSE:New video is the same as the old30624282: FPU:8087 only fpu code used esc 3: group 4: subfuntion :130821319: FILES:file open command 0 file C:\FRACTI~1.04P\fractint.cfg31391929: FILES:file open command 0 file C:\FRACTI~1.04P\FRACTINT.EXE31392054: FILES:file open command 0 file C:\FRACTI~1.04P\FRACTINT.EXE31392168: FILES:file open command 0 file C:\FRACTI~1.04P\FRACTINT.EXE31430137: FILES:file open command 0 file C:\FRACTI~1.04P\sstools.ini31453771: FILES:file open command 0 file C:\FRACTI~1.04P\maps\default.map31957227: FILES:file open command 0 file EMMXXXX031957236: IOCTL:07:Fakes output status is ready for handle 531957357: FILES:file open command 0 file EMMXXXX031957366: IOCTL:07:Fakes output status is ready for handle 531957409: FILES:file open command 0 file EMMXXXX031957418: IOCTL:07:Fakes output status is ready for handle 531958866: FILES:file open command 2 file TARGPLUS31959005: INT10:Set Video Mode 331959005: MOUSE:New video is the same as the old31959028: INT10:Function 12:Call 30 (select vertical resolution)31959142: INT10:Set Video Mode 331959142: MOUSE:New video is the same as the old32098823: VGA:h total 100 end 80 blank (80/98) retrace (85/97)32098823: VGA:v total 449 end 400 blank (407/442) retrace (412/414)32098823: VGA:h total 0.03178 (31.47kHz) blank(0.02542/0.03114) retrace(0.02701/0.03082)32098823: VGA:v total 14.26806 (70.09Hz) blank(12.93341/14.04562) retrace(13.09230/13.15585)37985741: FILES:file open command 0 file C:\FRACTI~1.04P\fractint.cfg42408904: INT10:Set Video Mode 1342408904: VGA:Blinking 042511472: VGA:h total 100 end 80 blank (80/98) retrace (84/96)42511472: VGA:v total 449 end 400 blank (407/442) retrace (412/414)42511472: VGA:h total 0.03178 (31.47kHz) blank(0.02542/0.03114) retrace(0.02669/0.03051)42511472: VGA:v total 14.26806 (70.09Hz) blank(12.93347/14.04568) retrace(13.09235/13.15591)42511472: VGA:Width 320, Height 200, fps 70.08630342511472: VGA:double width, double height aspect 1.20000054116175: INT10:Set Video Mode E54116182: IO:Read from port 03BA54116259: INT10:Set Video Mode 354116259: VGA:Blinking 854253919: VGA:h total 100 end 80 blank (80/98) retrace (85/97)54253919: VGA:v total 449 end 400 blank (407/442) retrace (412/414)54253919: VGA:h total 0.03178 (31.47kHz) blank(0.02542/0.03114) retrace(0.02701/0.03082)54253919: VGA:v total 14.26806 (70.09Hz) blank(12.93341/14.04562) retrace(13.09230/13.15585)54253919: VGA:Width 640, Height 400, fps 70.08659254253919: VGA:normal width, normal height aspect 1.00000057371112: IO:Read from port 03BA57371150: INT10:Set Video Mode E57371150: VGA:Blinking 057371157: IO:Read from port 03BA57371247: INT10:Set Video Mode 1357371263: IO:Read from port 03BA57499398: VGA:h total 100 end 80 blank (80/98) retrace (84/96)57499398: VGA:v total 449 end 400 blank (407/442) retrace (412/414)57499398: VGA:h total 0.03178 (31.47kHz) blank(0.02542/0.03114) retrace(0.02669/0.03051)57499398: VGA:v total 14.26806 (70.09Hz) blank(12.93347/14.04568) retrace(13.09235/13.15591)57499398: VGA:Width 320, Height 200, fps 70.08630357499398: VGA:double width, double height aspect 1.200000
