Phil's Ultimate VGA Benchmark Database Project
Reply 82 of 495, by Mau1wurf1977
keropi wrote:
Nice 😀
I still think though that 3DBENCH is quite useless... 🤣
Yea 😒
But it has it's place with slower computers. The only benchmark that runs on a 286 and it scales very well until it runs into faster Pentium III machines 😵
My YouTube channel
Reply 83 of 495, by Geoman
I tried MTRRLFBE on the Phenom II with no change in fps at all.
The Atom/GMA945 did not like MTRRLFBE - all the benchmarks crashed at start.
IBM Aptiva 2168-931
Reply 84 of 495, by keropi
Mau1wurf1977 wrote:
keropi wrote:
Nice 😀
Yea 😒
Well, it also craps out with the 486slc2 without cache enabled.
I don't know, I don't trust it even on slower machines after that... it's too unpredictable 😐
Reply 85 of 495, by Mau1wurf1977
Hmm I can't remember if I ran it on my Phenom II.
Hmm looks like I didn't input them. But I think AMD is just fast without any tools. The higher FSB of 200 might make a difference as well?
Did you try FASTVID? While I don't have it in the menu, it is in a folder. Might add it to the menu tomorrow just in case 😀
My YouTube channel
Reply 86 of 495, by Geoman
3DBench should remain in the suite IMHO... 😉
IBM Aptiva 2168-931
Reply 87 of 495, by Mau1wurf1977
It's a classic 😀 Great for quckly testing a 486 or Pentium. Doom takes too long on a 386. Imagine BIOS tuning with Doom. It would take weeks 😵
My YouTube channel
Reply 89 of 495, by Geoman
So back from DOS again: FASTVID works and the benchmarks work with FASTVID. But no change in fps at all on the Phenom II. So I think this combination of AMD Chipset + AMD CPU + AMD GPU is MS-DOS-ready without any tools. 😀
IBM Aptiva 2168-931
Reply 90 of 495, by Mau1wurf1977
I hear you keropi. I also agree that PCPBENCH is much better. I just can't believe how it scales from a 386 to an i7 in such a smooth fashion. Really impressive.
Wondering if the new AMDs or an i7 4770 can crack the 1000 fps in Quake 😈
My YouTube channel
Reply 91 of 495, by RacoonRider
Guys, do you have any idea why quake benchmark does not work when I boot from flash drive? I tested on Xeon and Atom systems, it returns
OMPT=: cannot open
Tried recopying the files, removing read-only attrib, nothing helps.
Reply 92 of 495, by Mau1wurf1977
RacoonRider wrote:
Guys, do you have any idea why quake benchmark does not work when I boot from flash drive? I tested on Xeon and Atom systems, it […]
OMPT=: cannot open
There are some tips on google:
https://groups.google.com/forum/#!topic/comp. … gpp/Kc803G_5jUU
Try setting a PATH variable
SET PATH=C:\
My YouTube channel
Reply 93 of 495, by Geoman
OMPT=: cannot open
Before starting Quake, the path-variable must be defined. Anything goes:
C:\> path bla
IBM Aptiva 2168-931
Reply 94 of 495, by Skyscraper
That sounds like a challange.
I do not own an i7 4770 but I think a fast Core 2 Duo system will get a nice score.
I will need to search through my mess to see if I can find a good CPU and some fast memory.
Reply 96 of 495, by RacoonRider
Thank you guys, it worked. I should have googled it in the first place 😁 Anyway, added Xeon 3230 and Atom N270 results.
It's interesting that Xeon shows an impressive boost from fastvid, while Atom shows exact same numbers!
Reply 97 of 495, by Skyscraper
@Default settings the Core 2 Duo E8600 got 878.2 FPS in Quake with a Radeon 5770
I will try a few other grapics card but it seems perhaps I have to overclock to reach 1000 FPS
I got a great Doom score though, 383 FPS!!
edit
the Geforce 7900 GTX really sucked
/edit
Reply 98 of 495, by GeorgeMan
Give us more preconfigured benches please! 😁
Acer Helios Neo 16 | i7-13700HX | 64G DDR5 | RTX 4070M | 32" AOC 75Hz 2K IPS + 17" DEC CRT 1024x768 @ 85Hz
Win11 + Virtualization => Emudeck @consoles | pcem @DOS~Win95 | Virtualbox @Win98SE & softGPU | VMware @2K&XP | ΕΧΟDΟS
Reply 99 of 495, by Skyscraper
Core 2 Duo E8600 @ 4500 MHz + Radeon 5770 Quake 1092.4 FPS
I am writing down the result in the normal table because I did not find the link to the overclocked one.
Feel free to move it as soon as I am done typing in the numbers.
