First post, by Aroduc
I'm having troubles getting Blood Bowl to run correctly under .61, and from a quick search, it would seem that it -should- be working under .61.
Blood bowl not working!!!!!!!
With a P4 and under XP, with XMS on and installed into c:\blood (both required for the game to operate), I can duplicate the error from above by setting the Eumlated CPU Core to Full. Under Normal, it gives a GRP:Illegal Call 7 error and shuts down. Turning off sound emulation causes the program to not boot at all as well, as it actively attempts to detect a sound blaster system and will not execute without one.
I tried running it with dos4gw as well, but I get a "can't load executable format for file bb.exe" error.
Playing around with the video setting seemed to accomplish absolutely nothing, though there may be some cryptic combination which I just missed.
So, uh, any ideas?
Thanks.
