First post, by johnny
i can run v0.60 very well on my machine, which is:
Windows 2000 SP4
Pentium 2 450MHz
256 MB ram
S3 Virge Dx/Gx video card
Creative AWE 64 sound card
DirectX 8.0
i wanted to try 0.61, but it doesn't work, starting it will bring the debugging console of dosbox, then the frame of dosbox screen, and inside it a copy of the screen of what was behind it, not the dosbox command screen. but it accepts command, as typing "exit [return]" will make it exit...
i tried putting other machines (vga, cga, auto) and render method (surface, overlay, opengl) the same result for the first too, and complete computer block for opengl...
why is this happening? with new versions, you execlude old machines from running dosbox?
