TANDY Dos-Gaming-Thread (1000RL/HD)
Getting old software/games running on older hardware.
Re: TANDY Dos-Gaming-Thread (1000RL/HD)
Postby dr.zeissler » 2014-11-04 @ 08:50
Do I understand this correctly that I need a special cable http://nerdlypleasures.blogspot.de/2014 ... plink.html in order to get a lap-link connection. I have a Standard Lap-Link cable here...but not tested.
Doc
CPU: PII 133-333 MOBO: SNI-D981 RAM: 512- FDD: Dualfloppy 3,5"HD/5,25"HD - 3,5"HD - 5,25"DD ISA-Catweasel HDD: 2x40GB - DVD
ISA(3): Audician32-S2Dreamblaster - GusACE PCI(3): Monster3D- Intel NW AGP(1): 3dfx V3-3000
dr.zeissler
Postby dr.zeissler » 2014-11-04 @ 23:57
I tested the "standard LapLink cable" and i can't get any connection :-(
dr.zeissler
Postby Cloudschatze » 2014-11-05 @ 00:27
Did you jumper/bridge E2-E3 on the motherboard to connect the required Select status line?
User avatar
Cloudschatze
Postby dr.zeissler » 2014-11-05 @ 07:20
no, I did not know about this...is this shown at the Tandy-faq?
dr.zeissler
Postby Cloudschatze » 2014-11-05 @ 17:41
The "semi-official" Tandy 1000 FAQ is outdated with respect to the parallel port capabilities. Most of the information and testing regarding bidirectional transfers is very recent.
Concering LapLink/Interlnk, Microsoft provides the following document, which shows the requirement for the Select status line on Pin 13 of the DB25 header:
http://support.microsoft.com/kb/121246
Connecting this status line is mentioned in a number of Tandy documents, and for various members of the 1000 family, but a specific reference to the RL is included in the "Notes and Jumpers" manual:
ftp://ftp.oldskool.org/pub/tvdog/tandy1 ... tejump.zip
Just be aware that even the Tandy documention describes the function of the modification incorrectly. The jumper connects the Select status line from a printer/device - not the Select control line to a printer/device.
I installed a three-pin jumper header in my RL, but (as I've mentioned a number of times on the VC forum now) you can also simply bridge the connection with a conductive pen, etc.
User avatar
Cloudschatze
Postby dr.zeissler » 2014-11-05 @ 19:37
Cool, THX!
This will enable either a LAPLINK-Connection (with Standard cable) or a Zipdrive!
This is nice!
(305.53 KiB) Not downloaded yet
dr.zeissler
Postby dr.zeissler » 2014-11-05 @ 19:39
...installing a jumper should be easy, but what means "installing staking pins" ?
E2-E3?
(193.01 KiB) Not downloaded yet
dr.zeissler
Postby dr.zeissler » 2014-11-05 @ 20:01
I think I have an idea...I have to put PINS at the correct place and connect them ?
This I cannot do, because I have no tools to change something on the board. It is extremly risky... i don't want to damage the machine.
dr.zeissler
Postby Cloudschatze » 2014-11-05 @ 21:30
dr.zeissler wrote:This will enable ... a Zipdrive!
Not a standalone Zip drive, no.
A parallel Zip drive will not work with the RL's built-in parallel port, even with the aforementioned modification. The internal parallel-to-SCSI chipset in these Zip drives requires the Select control line, which is not available in any PSSJ-bearing Tandy system.
A SCSI-connected Zip drive will work with the RL, if attached to a Shuttle-based parallel-to-SCSI interface, and assuming the E2-E3 jumper/bridge connection has been made. This is the configuration I use.
dr.zeissler wrote:...installing a jumper should be easy, but what means "installing staking pins" ?
E2-E3?
If you look at the RL motherboard, you'll find the filled holes for E2-E3-E4 near the J5 connector. With a solder sucker or copper braid, you can remove the solder from these holes and then solder in a three-pin header ("staking pins"), which you can then put a jumper shunt on. Not very risky at all.
If it's a concern though, you can buy one of these, and simply draw a line that connects E2 to E3:
http://www.amazon.de/Radio-Shack-276003 ... 004M2EFVW/
User avatar
Cloudschatze
Postby dr.zeissler » 2014-11-06 @ 09:27
I bought the PEN eBay: 201040761589.Though E2 and E3 are direct beside each other, so it should be not so difficult to connect both.
Is it a stable connection with a line of this PEN ?
As you mentioned this connection does not mean that i get a "normal" bidirectional" LPT Port, so no ZIP-Drive will work, but I can
connect the Tandy with a normal PC over a normal? LaplinkCable. Is that true? Or does it mean that I need a special wired LapLink-Cable?
Sorry for the questioning, my normal language is german, sorry.
Please make a picture of your connection of E2-E3. Thx.
Doc
dr.zeissler
Postby Cloudschatze » 2014-11-07 @ 15:52
dr.zeissler wrote:Is it a stable connection with a line of this PEN ?
It should be more than sufficient for this connection, yes.
I believe your normal LapLink cable should work fine.
User avatar
Cloudschatze
Postby dr.zeissler » 2014-11-08 @ 10:41
Thank You!
I know that the Tandy's are meant to be used with "Deskmate" but I want to use other GUI's too.
So I tested GEM1x, GEOS1x and WIN1.x yesterday, all work, but only in B/W mode, so no colors :-(
I searched the internet a lot, and I am nearly sure, that there will be no colors in the GUI's mentioned above.
Win2x has a Tandy-Driver but only 4colors, that won't help me much.
The Amstrad(PC1512,1640) had e.g. a special Mode with GEM2x that allows all 16colors at once, I haven't found
a special Tandy-Version like this Amstrad. http://www.seasip.info/Gem/Drivers/video.html
I think the fact is, that the Tandy's are meant to used with Deskmate and so, no other Gui's had got special Drivers
to support all native Colors at High-Resolutions. :-(
I thought I can use the galaxy-player (glx212) for playing MOD-Files other the Dac, but this nice player does
not work, but there must be a good alternative that works with the Tandy.
Deluxe paint features 320x200@16colors, but not 640x200@16colors. Is there any GFX-Program, GFX-Vierwer,
Paint-Program, Fractal-Generator that uses the Highresmode 640x200@16colors?
Thx
Doc
PS: Here are the Demo and the Sources of the best CGA-Demo I watched so far, if anyone is able to add music
to it (e.g. TLN The Wilderness) this would be very nice. http://bohemiq.scali.eu.org/CGADEMO.ZIP
dr.zeissler
Postby idspispopd » 2014-11-10 @ 13:24
dr.zeissler wrote:Thank You!
Actually, the Amstrad PC1640 has EGA compatible video, it is only the PC1512 which needs special drivers for its proprietary extended CGA capabilities.
Re GEM: If you have the specifications for the 640x200x16 Tandy mode, it shouldn't be too hard to make a driver. There are a lot of drivers including source code here, maybe the site's owner could help.
Re graphics viewer: According to this documentation CompuShow is able to use the mode:
T2=Tandy 1000SL/TL
640x200x16
idspispopd
Postby dr.zeissler » 2014-11-10 @ 17:58
Hi, I recently sent "John Elliott" an E-Mail, but he has not answeared yet.
dr.zeissler
Postby dr.zeissler » 2014-11-11 @ 14:07
I don't think that I can do a driver, because I have no idea about programming, but it would be extremly nice to have a GEM1.2 Driver.
The later Versions are not so good.
Today I got the PEN, so I could do the connection between E2 and E3.
Neardy-pleasures wrote about a special LAP-Link-Cable without making the Connection between E2 and E3. I must decide if it is the
better way to build a "special" Laplink-Cable or to modify the Mainboard.
In the past, I was not shy about letting old hardware be modified in order to get upgrades, but actual I am more interested in letting
the machine "as it was before" and accept the limitations.
Not so easy to decide :-(
dr.zeissler
Postby dr.zeissler » 2014-11-11 @ 14:17
Currently I am testing a lot of games with Tandy support. I use "myabandonware" for download.
A lot of games that are Tandy-compatible don't work with the download version because:
- The Tandyversion is a special one (perhaps on other Disks) e.g. Falcon (Spectrum Holobyte)
- The Tandysupport is not installed from the original Diskset (the installed Version is either CGA or EGA or both.)
So I need to search for the original Disksets as Download or go for the Original Disks at ebay.
PS: I have not found a Site yet witch has Diskimages of the Original Disksets.
dr.zeissler
Postby Great Hierophant » 2014-11-11 @ 14:47
dr.zeissler wrote:Today I got the PEN, so I could do the connection between E2 and E3.
Either you misread that blog entry or I made a mistake. If you want standard LapLink software to work in the RL, then you must bridge E2 and E3, otherwise you are missing a data bit, which is very bad.
User avatar
Great Hierophant
Postby dr.zeissler » 2014-11-11 @ 17:58
Then I misread that blog entry, sorry for that. I assume: In order to get a LapLink-Connection I MUST connect E2 with E3.
dr.zeissler
Postby dr.zeissler » 2014-11-23 @ 19:46
really cool stuff for an XT-CGA: http://scalibq.wordpress.com/2014/11/22 ... eblasters/
I haven't found a lot of Tandy.-Versions yet, dos anyone found them?
- Falcon (TandyDisk)
- North&South
- Xenon1
- 007 Bond
- Hostages
dr.zeissler
Postby filipetolhuizen » 2014-11-27 @ 02:49
I just tried Alley Cat in DOS Box emulating a PCjr and gosh, how it looks and sounds so much better! I've never seen it looking so good before.
User avatar
filipetolhuizen
PreviousNext
Return to Software
Who is online
Users browsing this forum: Caluser2000, PC Hoarder Patrol and 1 guest
