TANDY Dos-Gaming-Thread (1000RL/HD)
Reply 20 of 132, by dr.zeissler
Do I understand this correctly that I need a special cable http://nerdlypleasures.blogspot.de/2014/09/ta … nd-laplink.html in order to get a lap-link connection. I have a Standard Lap-Link cable here...but not tested.
Doc
CPU: PII 133-333 MOBO: SNI-D981 RAM: 512- FDD: Dualfloppy 3,5"HD/5,25"HD - 3,5"HD - 5,25"DD ISA-Catweasel HDD: 2x40GB - DVD
ISA(3): Audician32-S2Dreamblaster - GusACE PCI(3): Monster3D- Intel NW AGP(1): 3dfx V3-3000
Reply 21 of 132, by dr.zeissler
I tested the "standard LapLink cable" and i can't get any connection 🙁
Reply 23 of 132, by dr.zeissler
no, I did not know about this...is this shown at the Tandy-faq?
Reply 24 of 132, by Cloudschatze
The "semi-official" Tandy 1000 FAQ is outdated with respect to the parallel port capabilities. Most of the information and testing regarding bidirectional transfers is very recent.
Concering LapLink/Interlnk, Microsoft provides the following document, which shows the requirement for the Select status line on Pin 13 of the DB25 header:
http://support.microsoft.com/kb/121246
Connecting this status line is mentioned in a number of Tandy documents, and for various members of the 1000 family, but a specific reference to the RL is included in the "Notes and Jumpers" manual:
ftp://ftp.oldskool.org/pub/tvdog/tandy1000/do … ts/notejump.zip
Just be aware that even the Tandy documention describes the function of the modification incorrectly. The jumper connects the Select status line from a printer/device - not the Select control line to a printer/device.
I installed a three-pin jumper header in my RL, but (as I've mentioned a number of times on the VC forum now) you can also simply bridge the connection with a conductive pen, etc.
Reply 25 of 132, by dr.zeissler
Cool, THX!
This will enable either a LAPLINK-Connection (with Standard cable) or a Zipdrive!
This is nice!
    305.53 KiB
    No downloads
Reply 26 of 132, by dr.zeissler
...installing a jumper should be easy, but what means "installing staking pins" ?
E2-E3?
    193.01 KiB
    No downloads
Reply 27 of 132, by dr.zeissler
I think I have an idea...I have to put PINS at the correct place and connect them ?
This I cannot do, because I have no tools to change something on the board. It is extremly risky... i don't want to damage the machine.
Reply 28 of 132, by Cloudschatze
dr.zeissler wrote:
This will enable ... a Zipdrive!
Not a standalone Zip drive, no.
A parallel Zip drive will not work with the RL's built-in parallel port, even with the aforementioned modification. The internal parallel-to-SCSI chipset in these Zip drives requires the Select control line, which is not available in any PSSJ-bearing Tandy system.
A SCSI-connected Zip drive will work with the RL, if attached to a Shuttle-based parallel-to-SCSI interface, and assuming the E2-E3 jumper/bridge connection has been made. This is the configuration I use.
E2-E3?
If you look at the RL motherboard, you'll find the filled holes for E2-E3-E4 near the J5 connector. With a solder sucker or copper braid, you can remove the solder from these holes and then solder in a three-pin header ("staking pins"), which you can then put a jumper shunt on. Not very risky at all.
If it's a concern though, you can buy one of these, and simply draw a line that connects E2 to E3:
http://www.amazon.de/Radio-Shack-2760037-Cond … /dp/B004M2EFVW/
Reply 29 of 132, by dr.zeissler
I bought the PEN eBay: 201040761589.Though E2 and E3 are direct beside each other, so it should be not so difficult to connect both.
Is it a stable connection with a line of this PEN ?
As you mentioned this connection does not mean that i get a "normal" bidirectional" LPT Port, so no ZIP-Drive will work, but I can
connect the Tandy with a normal PC over a normal? LaplinkCable. Is that true? Or does it mean that I need a special wired LapLink-Cable?
Sorry for the questioning, my normal language is german, sorry.
Please make a picture of your connection of E2-E3. Thx.
Doc
Reply 30 of 132, by Cloudschatze
It should be more than sufficient for this connection, yes.
I believe your normal LapLink cable should work fine.
Reply 31 of 132, by dr.zeissler
Thank You!
I know that the Tandy's are meant to be used with "Deskmate" but I want to use other GUI's too.
So I tested GEM1x, GEOS1x and WIN1.x yesterday, all work, but only in B/W mode, so no colors 🙁
I searched the internet a lot, and I am nearly sure, that there will be no colors in the GUI's mentioned above.
Win2x has a Tandy-Driver but only 4colors, that won't help me much.
The Amstrad(PC1512,1640) had e.g. a special Mode with GEM2x that allows all 16colors at once, I haven't found
a special Tandy-Version like this Amstrad. http://www.seasip.info/Gem/Drivers/video.html
I think the fact is, that the Tandy's are meant to used with Deskmate and so, no other Gui's had got special Drivers
to support all native Colors at High-Resolutions. 🙁
I thought I can use the galaxy-player (glx212) for playing MOD-Files other the Dac, but this nice player does
not work, but there must be a good alternative that works with the Tandy.
Deluxe paint features 320x200@16colors, but not 640x200@16colors. Is there any GFX-Program, GFX-Vierwer,
Paint-Program, Fractal-Generator that uses the Highresmode 640x200@16colors?
Thx
Doc
PS: Here are the Demo and the Sources of the best CGA-Demo I watched so far, if anyone is able to add music
to it (e.g. TLN The Wilderness) this would be very nice. http://bohemiq.scali.eu.org/CGADEMO.ZIP
Reply 32 of 132, by idspispopd
dr.zeissler wrote:
Thank You! […]
Thank You!
Actually, the Amstrad PC1640 has EGA compatible video, it is only the PC1512 which needs special drivers for its proprietary extended CGA capabilities.
Re GEM: If you have the specifications for the 640x200x16 Tandy mode, it shouldn't be too hard to make a driver. There are a lot of drivers including source code here, maybe the site's owner could help.
Re graphics viewer: According to this documentation CompuShow is able to use the mode:
T2=Tandy 1000SL/TL
640x200x16
Reply 33 of 132, by dr.zeissler
Hi, I recently sent "John Elliott" an E-Mail, but he has not answeared yet.
Reply 34 of 132, by dr.zeissler
I don't think that I can do a driver, because I have no idea about programming, but it would be extremly nice to have a GEM1.2 Driver.
The later Versions are not so good.
Today I got the PEN, so I could do the connection between E2 and E3.
Neardy-pleasures wrote about a special LAP-Link-Cable without making the Connection between E2 and E3. I must decide if it is the
better way to build a "special" Laplink-Cable or to modify the Mainboard.
In the past, I was not shy about letting old hardware be modified in order to get upgrades, but actual I am more interested in letting
the machine "as it was before" and accept the limitations.
Not so easy to decide 🙁
Reply 35 of 132, by dr.zeissler
Currently I am testing a lot of games with Tandy support. I use "myabandonware" for download.
A lot of games that are Tandy-compatible don't work with the download version because:
- The Tandyversion is a special one (perhaps on other Disks) e.g. Falcon (Spectrum Holobyte)
- The Tandysupport is not installed from the original Diskset (the installed Version is either CGA or EGA or both.)
So I need to search for the original Disksets as Download or go for the Original Disks at ebay.
PS: I have not found a Site yet witch has Diskimages of the Original Disksets.
Reply 36 of 132, by Great Hierophant
Either you misread that blog entry or I made a mistake. If you want standard LapLink software to work in the RL, then you must bridge E2 and E3, otherwise you are missing a data bit, which is very bad.
Reply 37 of 132, by dr.zeissler
Then I misread that blog entry, sorry for that. I assume: In order to get a LapLink-Connection I MUST connect E2 with E3.
Reply 38 of 132, by dr.zeissler
really cool stuff for an XT-CGA: http://scalibq.wordpress.com/2014/11/22/cgade … y-codeblasters/
I haven't found a lot of Tandy.-Versions yet, dos anyone found them?
- Falcon (TandyDisk)
- North&South
- Xenon1
- 007 Bond
- Hostages
Reply 39 of 132, by filipetolhuizen
I just tried Alley Cat in DOS Box emulating a PCjr and gosh, how it looks and sounds so much better! I've never seen it looking so good before.
