Reply 361 of 495, by kixs
- l33t
wrote:Finally got my GA486AM/S working with AMD 5x86-P75 in WB mode. […]
Config:
GA486AM/S v2.21, 256KB 15ns cache
AMD 5x86-P75 133MHz
2x4MB FPM RAM
Tseng ET6000 2.25MB PCI
BIOS set to fastest settings
Upgraded cache to 512KB (AMD@160MHz-WB):
3DBench...98.8
PCPlayer...25.6
Doom...1232
Quake...15.5
Visit my AmiBay items for sale (updated: 2025-03-14). I also take requests 😉
Reply 362 of 495, by easy_john
- Member
If we talking about overclocked 486, I've get faster possible results on 5x86-133mzh on 50 mhz bus:
33x4 (130mhz): 81,3 / 20,4 / 1597 / 12,6
50x3 (150mhz): 103,3 / 25,2 / 1258 / 15,1
PS but you need fast pci video card, that can run on 50 mhz pci. ET6000 for example.
Pentium2 450/256mb/4gb/ati rage 128+voodoo2/SB awe32 8mb+db50xg/GUS PnP 8mb/TB Tropez 2mb
486 DX2-66/32mb/8gb/tseng4000 2mb/SB 16+WB/GUS 1mb/LAPC-I
286 12mhz/4mb/512mb/Vga 1mb/SB 2.0+Covox
PegasosII G4 / Amiga 4000 / Amiga1200 / Amiga 600
Reply 363 of 495, by Lukeno94
wrote:Nice, I don't think I've seen a CL2 PC133 memory module myself 😀
It's laptop memory, so I'm a little dubious, but it does report as being CL2 at PC133, and CL3 at PC142 IIRC.
Reply 364 of 495, by RacoonRider
- Oldbie
Phil, could you sort the table?
Reply 365 of 495, by PhilsComputerLab
Reply 366 of 495, by easy_john
- Member
wrote:Done!
And how about overclocked table? )
Reply 367 of 495, by PhilsComputerLab
Reply 368 of 495, by Lukeno94
The validation for the 3DBench table is broken... no good supporting only three digits and getting people to input "Too fast" instead on the 3DBENCH field if it won't accept the "too fast" bit (also, there's a typo in the validation comment)! Just ran tests with the Dell Latitude C600 1GHz PIII and the Dell Latitude CP M233ST under Windows 98... the C600 seems to be bizarrely good at 3DBench when VGABOOST is used. I know it was a four-figure number for the 1GHz speed based on the results of the 700 MHz speed.
Reply 369 of 495, by PhilsComputerLab
- l33t++
Thanks I'll sort it out.
Also I think this project has run long enough. We have over 500 entries, much more than I envisioned and lots of data for users to compare. So at the end of the month this project won't be taking any more entries but stay online for people to access and download.
I'm eager to start something new 😀
Reply 370 of 495, by RacoonRider
- Oldbie
wrote:Thanks I'll sort it out.
What's the point of killing it? Let the people add 2-3 entries a month, it's not like you have to do much.
Reply 371 of 495, by kixs
- l33t
Keep it alive 😉
Reply 372 of 495, by easy_john
- Member
Keep it alive, please.
Still have few old platform to bench and compare.
Reply 373 of 495, by GeorgeMan
- Oldbie
Keep it open for new entries please! 😁
Acer Helios Neo 16 | i7-13700HX | 64G DDR5 | RTX 4070M | 32" AOC 75Hz 2K IPS + 17" DEC CRT 1024x768 @ 85Hz
Win11 + Virtualization => Emudeck @consoles | pcem @DOS~Win95 | Virtualbox @Win98SE & softGPU | VMware @2K&XP | ΕΧΟDΟS
Reply 374 of 495, by Godlike
I've got pair of them in my hands KVR133X64C2/256 they are for CUSL2_C
Also keep ita alive! 😊
ASUS P2B-F, PII 450Mhz, 128MB-SDR, 3Dfx Diamond Monster 3D II SLI, Matrox Millennium II AGP, Diamond Monster Sound MX300
Reply 375 of 495, by GeorgeMan
- Oldbie
Added 8 new entries!
Will add many more tomorrow!
Cannot enter "too fast" in 3dbench column!
Reply 376 of 495, by Thraka
- Member
Why is this not stickied?
Reply 377 of 495, by Stiletto
- l33t++
wrote:Why is this not stickied?
Dunno. We can do it if you want.
That said, if we stickied everything cool and interesting in Marvin, the first page of posts would be nothing but stickies 😀
do the Fandango!" - Queen
Stiletto
Reply 378 of 495, by Thraka
- Member
You could make a single sticky topic that points to all the database topics. 😀 That would cut out 2 or 3 of your current stickies.
Reply 379 of 495, by Tertz
CPU frequencies in "emulators" section may be higher for CPUs having "boost" like i7 3770. As DOSBox uses only 1 core, then 3770 should work at 3.9 GHz, not 3.4. Real working frequency during test may be checked by cpu-z (as cpu-z slowes down CPU, so fps should be measured without it in memory and frequency checked in the next run).
CPUs in "stock" section should be only at native frequencies, without reduced ones. For example at line 405, I see Pentium III Coppermine E 1000 with 100x7.5. If it's not a mistyping.
