First post, by dnewhous
When you set the sampling rate in DOSbox does that fix the sampling rate for both mono and stereo audio streams?
I found an interesting web site here http://sox.sourceforge.net/AudioFormats-5.html
that says the SB Pro does 44.1k in mono and 22k in stereo. For those running computer operating on the edge of sputtering this is an important issue.
Does anyone know the sampling rate on the original soundblaster?
Reply 1 of 6, by DOS_Boy
As far as I know, the standard for DOS applications on original Sound Blaster cards, especially games, is 22050 Hz, Mono, 8/16 bit. depends on the type of the card. I have an original Sound Blaster 16 PnP on my 486, it is the last type of cards made back then, and I have no problem at all running apps and games on 16 bit. Hope I could help you on that. Laterz...
"But listen to me brother, you just keep on walking, 'cause you and me and sister ain't got nothing to hide..." - Scatman John
Reply 2 of 6, by DevilMan
Yes. i have the same problem on latest CVS and IT 2.14 - sampling rate of SB cards is 22k, no matter what you write in .conf file.
hey ho let's go
Reply 3 of 6, by Freddo
The Sound Blaster Pro play stereo in 22khz. The Sound Blaster 16 was the first Sound Blaster that could play stereo in 44khz. So you have to wait until the SB16 is fully emulated by DOSBox.
Reply 4 of 6, by dnewhous
The other question here is, "What does the DOSbox setting mean?"
Does it mean mono or stereo at the configured sampling rate? Stereo at the configured sampling rate and mono at twice that?
Reply 5 of 6, by Freddo
It means what the output of DOSBox will be. So if a sound plays in 22khz internally, it then will be converted into whatever your DOSBox option is before it's actually played.
Reply 6 of 6, by dnewhous
You reply begs the question. Mono or stereo or both?
