First post, by dnewhous
- Member
When you set the sampling rate in DOSbox does that fix the sampling rate for both mono and stereo audio streams?
I found an interesting web site here http://sox.sourceforge.net/AudioFormats-5.html
that says the SB Pro does 44.1k in mono and 22k in stereo. For those running computer operating on the edge of sputtering this is an important issue.
Does anyone know the sampling rate on the original soundblaster?
