Reversing the Disney Sound Source
Reply 40 of 148, by DonutKing
Very nice work - will have to build one when its complete 😀
Reply 42 of 148, by shock__
CD40105 variant added, component placement map added, custom Eagle library added & documentation updated.
Current Project: new GUS PnP compatible soundcard
[Z?]
Reply 44 of 148, by Harekiet
Rank DOSBox Author
DOSBox Author
Nice 😀 I hear sounds!
Reply 45 of 148, by carlostex
I thought i remembered the guards screaming in Wolf 3D with my original DSS. I might be wrong though. Any kind of limitation with this design?
Reply 46 of 148, by shock__
No, Wolf3D's sound engine is crap ... it's limited to outputing 1 sound with no software mixing ... so if a sound is playing already the new one is skipped.
That's why I waited before opening the door to Hans Grosse and closing the door before the "end sequence".
Actually ... seems like the truth is somewhere in between:
https://www.youtube.com/watch?v=kN30QELXiZw
[Z?]
Reply 47 of 148, by shock__
Alone in the dark confirmed as working (it's "broken" in DOSBox [or rather not fixed since AITD's detection routine is stupid]), while Dungeon Master does NOT work.
EDIT: DM works with the -sd2 parameter
[Z?]
Reply 48 of 148, by shock__
Dungeon Master detection routine confirmed working with the 74ALS232 variant (it's extremely picky about the timing, so one might have to re-adjust the variable resistor a few times)
http://i.imgur.com/bllkrgw.jpg
EDIT: Also works with the CD40105 variant ... or a mix between both ICs (as long as you keep the different signal levels for OE and RESET between both chips in mind). I guess this project can be considered a full success 😀
[Z?]
Reply 49 of 148, by matze79
Thanks spend a bit of time to make one:
The attachment DSC_0052.jpg is no longer available
The attachment DSC_0051.jpg is no longer available
http://www.dosforum.de/viewtopic.php?f=29&t=10210
Time to Test it 😀
https://www.youtube.com/watch?v=pnncFNkkI6s&f … player_embedded
https://www.youtube.com/watch?feature=player_ … d&v=LUCiWou-xcs
Reply 50 of 148, by BishopHavok
Looks cool as heck.
Reply 51 of 148, by stamasd
Regarding the Covox/DSS, I see mentions of "mono", "stereo-on-1" and "stereo-on-2". Mono is obvious, and I think I figured what the "stereo-on-1" means. But I can't figure out what "stereo-on-2" is.
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 52 of 148, by Jepael
Two mono covoxes on two LPT ports.
But I have to add that while Covox and DSS are both LPT port DACs, they are completely different and not compatible. Samples need to be written to DSS with a load strobe and they go into 16 sample FIFO that can signal when it's full and samples are played back at fixed 7kHz rate, while Covox is just a DAC that will output whatever is on LPT data pins at any time.
Reply 53 of 148, by stamasd
Yeah that makes more sense. Prone to desynchronization probably.
Yes, that part was clear.
I/O, I/O,
I/O, I/O
Reply 54 of 148, by dr.zeissler
Can someone give us a status update of the dss/covox project ?
thx
doc
Reply 55 of 148, by rorysl
Very interested as well!
Reply 56 of 148, by Paralel
Also quite interested.
Reply 57 of 148, by Paralel
Think we can convince Dreamblaster to make a CVX4 + DSS Dongle pack?
Seems like it would be an even better seller than the CVX4 by itself because it would vastly increase the number of titles that could be used with it.
Reply 58 of 148, by matze79
I ordered a patch of pcbs with shockwav3's design.
so in a couple of days/weeks i will have a version on pcb 😀
also made a covox with dac ic.. but still only schematic and brd on my desk.
had no time to make a pcb for now.
But i will do in the next months.
Its full chip dac but only mono, with lpt passtrough.
So i don't have to unplug printer/etc..
Reply 59 of 148, by tabm0de
Im also intressted! 😀
naa, nothing yet...
