Reversing the Disney Sound Source
Discussion about old sound cards, MIDI devices and sound related accessories.
Re: Reversing the Disney Sound Source
Postby DonutKing » 2015-2-15 @ 01:25
Very nice work - will have to build one when its complete :)
User avatar
DonutKing
Postby hard1k » 2015-2-15 @ 03:59
Hey, I would be interested too.
Please have a look at my wishlist (hosted at Amibay)
User avatar
hard1k
Postby shock__ » 2015-2-15 @ 15:15
CD40105 variant added, component placement map added, custom Eagle library added & documentation updated.
dss_emu.zip
Updated files (schematics, layout examples, documentation) for building a Disney Sound Source compatible circuit.
(487.02 KiB) Downloaded 235 times
User avatar
shock__
Postby shock__ » 2015-3-25 @ 11:04
Just as a small finisher, a video showing the DSS emulator in action (sound recorded via line in on my main PC):
https://www.youtube.com/watch?v=EoGCf69 ... e=youtu.be
User avatar
shock__
Postby Harekiet » 2015-3-25 @ 13:03
Nice :) I hear sounds!
User avatar
Harekiet
DOSBox Author
Postby carlostex » 2015-3-25 @ 16:24
I thought i remembered the guards screaming in Wolf 3D with my original DSS. I might be wrong though. Any kind of limitation with this design?
User avatar
carlostex
Postby shock__ » 2015-3-25 @ 18:23
carlostex wrote:I thought i remembered the guards screaming in Wolf 3D with my original DSS. I might be wrong though. Any kind of limitation with this design?
No, Wolf3D's sound engine is crap ... it's limited to outputing 1 sound with no software mixing ... so if a sound is playing already the new one is skipped.
That's why I waited before opening the door to Hans Grosse and closing the door before the "end sequence".
Actually ... seems like the truth is somewhere in between:
https://www.youtube.com/watch?v=kN30QELXiZw
User avatar
shock__
Postby shock__ » 2015-3-27 @ 22:00
Alone in the dark confirmed as working (it's "broken" in DOSBox [or rather not fixed since AITD's detection routine is stupid]), while Dungeon Master does NOT work.
EDIT: DM works with the -sd2 parameter
User avatar
shock__
Postby shock__ » 2015-4-05 @ 14:35
Dungeon Master detection routine confirmed working with the 74ALS232 variant (it's extremely picky about the timing, so one might have to re-adjust the variable resistor a few times)
http://i.imgur.com/bllkrgw.jpg
EDIT: Also works with the CD40105 variant ... or a mix between both ICs (as long as you keep the different signal levels for OE and RESET between both chips in mind). I guess this project can be considered a full success :)
User avatar
shock__
Postby matze79 » 2016-1-31 @ 10:59
https://www.retroianer.de
matze79
Postby BishopHavok » 2016-11-07 @ 15:11
Looks cool as heck.
BishopHavok
Postby stamasd » 2016-11-09 @ 12:16
Regarding the Covox/DSS, I see mentions of "mono", "stereo-on-1" and "stereo-on-2". Mono is obvious, and I think I figured what the "stereo-on-1" means. But I can't figure out what "stereo-on-2" is.
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
stamasd
Postby Jepael » 2016-11-09 @ 17:28
stamasd wrote:Regarding the Covox/DSS, I see mentions of "mono", "stereo-on-1" and "stereo-on-2". Mono is obvious, and I think I figured what the "stereo-on-1" means. But I can't figure out what "stereo-on-2" is.
Two mono covoxes on two LPT ports.
But I have to add that while Covox and DSS are both LPT port DACs, they are completely different and not compatible. Samples need to be written to DSS with a load strobe and they go into 16 sample FIFO that can signal when it's full and samples are played back at fixed 7kHz rate, while Covox is just a DAC that will output whatever is on LPT data pins at any time.
Jepael
Postby stamasd » 2016-11-09 @ 22:19
Yeah that makes more sense. Prone to desynchronization probably.
Yes, that part was clear.
I/O, I/O,
I/O, I/O
stamasd
Postby dr.zeissler » 2017-8-17 @ 14:17
Can someone give us a status update of the dss/covox project ?
thx
doc
CPU: PII 133-333 MOBO: SNI-D981 RAM: 512- FDD: Dualfloppy 3,5"HD/5,25"HD - 3,5"HD - 5,25"DD ISA-Catweasel HDD: 2x40GB - DVD
ISA(3): Audician32-S2Dreamblaster - GusACE PCI(3): Monster3D- Intel NW AGP(1): 3dfx V3-3000
dr.zeissler
Postby rorysl » 2017-8-21 @ 21:31
Very interested as well!
rorysl
Postby Paralel » 2017-8-26 @ 04:03
Also quite interested.
Paralel
Postby Paralel » 2017-8-27 @ 21:57
Think we can convince Dreamblaster to make a CVX4 + DSS Dongle pack?
Seems like it would be an even better seller than the CVX4 by itself because it would vastly increase the number of titles that could be used with it.
Paralel
Postby matze79 » 2017-10-06 @ 19:00
I ordered a patch of pcbs with shockwav3's design.
so in a couple of days/weeks i will have a version on pcb :)
also made a covox with dac ic.. but still only schematic and brd on my desk.
had no time to make a pcb for now.
But i will do in the next months.
Its full chip dac but only mono, with lpt passtrough.
So i don't have to unplug printer/etc..
matze79
Postby tabm0de » 2017-10-09 @ 21:58
Im also intressted! :)
naa, nothing yet...
User avatar
tabm0de
PreviousNext
Return to Sound
Who is online
