Reply 60 of 97, by subhuman@xgtx
Thanks everyone 😀 I've just updated my previous post with the missing 'stock clock' results.
Unfortunately I don't have Forsaken but I'll see if I can get hold of a copy and test it with this rig 😀
Regarding UT, I guess all of us are using the default intro flyby to bench the game?, right? I suggest that we timedemo UTBench instead to get more real-world results of how our systems will perform under a realistic gaming scenario with a reasonable amount of players blasting each other across an entire map 😀
Bear in mind I usually post to the forums using my old systems.
Reply 62 of 97, by Gamecollector
It's d3d only so you not lost anything.
Reply 63 of 97, by raymangold
Hey Phil, do you have the diamond drivers for that diamond monster sound vortex 2? I did some quick searches and couldn't find any except reference drivers.
I happened to find the same card in a PC I gutted.
Reply 64 of 97, by F2bnp
Sorry for the utter crap quality, these are my two main retro systems. In the center I've got the Tualatin, on which I did the tests, and on the right the K6-III+ with a Voodoo3. There's also an Athlon 64 system on the left that I fool around with sometimes. Maybe I'll open up a thread with much higher res and in-depth photos at some point.
Reply 65 of 97, by PhilsComputerLab
They are on the Vogons driver archive 😀
But for this system, I used the latest reference drivers. 2048.
YouTube, Facebook, Website
Reply 66 of 97, by Arctic
Work in progress for the challenge:
Pentium III-S 1400MHz (Tualatin-512k) SL6BY
512MB SD133 2-3-2-8
Asus TUSL2-C
Voodoo 5 5500 64MB AGP 2x
Reply 67 of 97, by PhilsComputerLab
Great machine!
Reply 68 of 97, by blank001
Phil, can you do a full CPU scaling write up like you did for the voodoo^2?
_: K6-III+ 450apz@550, P5A-B, 128Mb CL2, Voodoo 5500 AGP, MX300, AWE64 Gold 32mb, SC-55v2.0
_: Pentium III 1400 S, TUSL2-C, 512Mb CL2, Voodoo 5500 AGP, MX300
Reply 69 of 97, by PhilsComputerLab
😊 Sorry, but no. That paper was a once in a life project 😵
Reply 70 of 97, by GeorgeMan
A very nice one, that made me buy a powerleap adapter and put a Tualatin Celeron 1.1GHz into an ASUS P2B (i440bx), because it'd push the Voodoo2 SLI much more than the PIII 500MHz it had originally installed. 😉
Acer Helios Neo 16 | i7-13700HX | 64G DDR5 | RTX 4070M | 32" AOC 75Hz 2K IPS + 17" DEC CRT 1024x768 @ 85Hz
Win11 + Virtualization => Emudeck @consoles | pcem @DOS~Win95 | Virtualbox @Win98SE & softGPU | VMware @2K&XP | ΕΧΟDΟS
Reply 71 of 97, by blank001
You need to find local apprentices to do the grunt work of swapping CPU's and boards and such. Then you can just write up and analyze the data.
Reply 72 of 97, by PhilsComputerLab
Well, the thing is, I love that grunt work 😊
Just not THAT MUCH 🤣
I can't remember how long it took me, but towards the end it felt like work and couldn't wait for it to be finished. With other projects I'm a bit gutted when it's done because it means I got to find a new one. But that's ok 😀
In terms of V5 scaling, I believe we can all see the trend. You don't have a V5 and play at 640 x 480. Interesting to see differences in processing power, but most will play at 1024 x 768 minimum. At that resolution, I find a Pentium with 1 GHz or so to be fast enough. But a Tualatin, IMO, is THE perfect match for a V5, even though Athlon is faster, it just doesn't feel "right" 🤣
Reply 73 of 97, by Arctic
This topic is an oooold one 😁
Phil that research that you did on the Voodoo 2 scaling was badass! Kudos to you!
This is what I dug up:
it was made in 2004 by VoodooAlert.de forum member Friday_13th
Reply 74 of 97, by Evert
Reading all the posts and seeing all the nice data just makes me wish that my missing parts were here already. I spent a small fortune on it, but being a Voodoo 5 owner is something special and I'm so happy I can be a part of it.
Reply 75 of 97, by boxpressed
I just unboxed a V5 that I had purchased last year, so here are the benchmarks from my unexotic but stable SE440BX-2 system.
INTEL SE440BX-2
PIII-1000 SLOT 1 COPPERMINE
VOODOO 5 5500 AGP (1.04 DRIVERS)
AUREAL VORTEX 2 (AU8830)
256 MB GENERIC PC100 SDRAM
160GB WD CAVIAR SE HDD
WINDOWS 98SE
UNREAL GOLD (framerates taken from the third cycle)
800x600 : 113.7 (105.9)*
1024x768 : 99.1 (95.0)*
1600x1200 : 51.9 (52.5)*
* I forgot I had turned on the "Use3DHardware" option for the A3D in unreal.ini as well as bumping the sample rate to 48000Hz. These are the scores in parens.
UT99 GOTY (framerates taken from the third cycle)
800x600 : 73.25
1024x768 : 71.85
1600x1200 : 52.14
QUAKE 2 3.20 default OpenGL (framerates taken from third cycle)
800x600 : 163.6
1024x768 : 152.0
1600x1200 : 66.3
GLQuake 1.09/0.97 (framerates taken from third cycle)
800x600 : 194.9
1024x786 : 127.3
1600x1200 : 57.5
Reply 76 of 97, by PhilsComputerLab
Enabling A3D and boosting the sampling rate is very good, but I didn't do this for this project. Actually I forgot about it 😊 Everything is default, so to make it easier to compare.
Nice system BTW.
Reply 77 of 97, by boxpressed
Nice system BTW.
I thought I would include those rates since I had to rerun the tests with the default settings anyway. Love A3D. Have a Quadzilla on the way.
I will post another update once I get my Tualeron 1300 set up with the Powerleap adapter.
Reply 78 of 97, by boxpressed
boxpressed wrote:
I just unboxed a V5 that I had purchased last year, so here are the benchmarks from my unexotic but stable SE440BX-2 system. […]
INTEL SE440BX-2
WINDOWS 98SE
800x600 : 73.25
1024x768 : 71.85
1600x1200 : 52.14
800x600 : 163.6
1024x768 : 152.0
1600x1200 : 66.3
800x600 : 194.9
1024x786 : 127.3
1600x1200 : 57.5
OK, I finally got my Celeron Tualatin 1300 working with the Powerleap and SE440BX-2, so here are the results from that combo:
800x600 : 126.8
1024x768 : 106.4
1600x1200 : 51.9
800x600 : 83.55
1024x768 : 81.36
1600x1200 : 53.49
800x600 : 189.2
1024x768 : 157.9
1600x1200 : 66.8
800x600 : 194.7
1024x768 : 127.3
1600x1200 : 57.9
With the exception of GLQuake, gains at lower resolutions and nothing at 1600x1200. Not sure why GLQuake stayed the same at every resolution.
Reply 79 of 97, by Snayperskaya
Cool!
I think you should send me all your 1+TB drives. I'll gladly send you lots of 80/160GB SATAs 😁
