2mg wrote:Quick question: DOSBox supports OGL, why not GLSL/.cg filters?
Also, to be on topic, xBRZ - waiting for Zenju...
fingers2013 wrote:What a fantastic image resizer! I'm definitely going to make use of it in some of my projects!
If anyone is looking for the broken byuu.org link from the first post of this thread, it is now available here - http://board.byuu.net/viewtopic.php?f=10&t=2248
kolano wrote:fingers2013 wrote:What a fantastic image resizer! I'm definitely going to make use of it in some of my projects!
Yeah, unfortunately Byuu ran into some problems with his hosting provider which caused a variety of issues with his forums. He's still working on getting new ones up, but it seems like it may take a while.
ZenJu wrote:dosbox.conf should be setup with the following configuation:output=surface
fullresolution=original
scaler=none
aspect=false
fullscreen=true
Hi ZenJu! Is this all we need to do? And, since later SVN builds have xBRZ implemented, should we switch out scaler=none to scaler=xbrz while letting the other commands be as they are here?
Note: the updated version v3 will automatically apply these setttings. So you can simply copy the .exe into your Dosbox directory and start it.
Rod Primitive wrote:Update 2: I suppose this works just fine with latest Daum build as well?
Update: Ugh, I'm a retard.![]()
It was so simple to set it all up. I'm in love with this scaler!![]()
What .exe? This one?
Sorry if I'm asking the obvious, this is a bit new to me.
ykhwong wrote:The latest xbrz patch for DOSBox from ZenJu does not include scaler=xbrz.
(I fiddled with the patch to provide the scaler option in the daum builds for convenience.)
Basically with the above dosbox.conf setup (output=surface, scaler=none, fullscreen=true), it just forces to use the xbrz scaler.
Rod Primitive wrote:So what you're saying is that by setting output=surface, scaler=none, fullscreen=true activates xBRZ in Daum? We do not need to set scaler to =xBRZ then?
ykhwong wrote:Rod Primitive wrote:So what you're saying is that by setting output=surface, scaler=none, fullscreen=true activates xBRZ in Daum? We do not need to set scaler to =xBRZ then?
I mean the "scaler=xbrz" is Daum build-specific, which requires scaler=xbrz, output=surface, fullscreen=true to activate the xbrz scaling. On the other hand, the other builds that implement the xbrz scaling may not need to set scaler=xbrz at all.
ZenJu wrote:DOSBox v0.74 + xBRZ + Save States support:
http://sourceforge.net/projects/xbrz/files/DOSBox/
Dominus wrote:Click on that link and READ
Users browsing this forum: No registered users and 0 guests
