Great PC! But can it run Crysis?
Reply 20 of 241, by squareguy
I wish I could participate on my 98 Monster 🙁
Intel SE440BX-2 Motherboard
Intel Pentium III 450 CPU
Micron 384MB SDRAM (3x128)
Windows 98 SE
Reply 21 of 241, by AlphaC
Pretty glitchy / jerky and it quit's with an error.
Result:
Reply 22 of 241, by blank001
This is me
2600k @ 4.4Ghz
Gigabyte Z77X-UD5H
Sapphire Vapor-X 7970 Ghz Edition
32Gb Crucial @ 1600/1.35v
15.7 catalyst
Win 8.1
_: K6-III+ 450apz@550, P5A-B, 128Mb CL2, Voodoo 5500 AGP, MX300, AWE64 Gold 32mb, SC-55v2.0
_: Pentium III 1400 S, TUSL2-C, 512Mb CL2, Voodoo 5500 AGP, MX300
Reply 23 of 241, by calvin
So does Crysis require SSE2? If not, I have a cunning plan...
2xP2 450, 512 MB SDR, GeForce DDR, Asus P2B-D, Windows 2000
P3 866, 512 MB RDRAM, Radeon X1650, Dell Dimension XPS B866, Windows 7
M2 @ 250 MHz, 64 MB SDE, SiS5598, Compaq Presario 2286, Windows 98
Reply 24 of 241, by blank001
obobskivich wrote:
This was actually faster/easier than some "actual" benchmarks. I dig it. :exclamation: :happy: […]
This was actually faster/easier than some "actual" benchmarks. I dig it. 😲 😀
Results:
I couldn't help myself - had to crop! 😊
I'm currently waiting on new memory, so this will be a neat benchmark of what kind of improvement that makes (assuming I remember to run it again 🤣 ). CPU is at stock settings, including SpeedStep, so that's why you're seeing 800MHz in the window on the desktop. CPU-Z doesn't appear to graph clocks, like GPU-Z does, so I don't know what it was doing while running. 😊
I may also have to try playing the demo too... 🤣
As far as "slowest possible" - I'll see if there's any chance this will start on GeForce FX. 😈
Is that a 290X? You should checkout catalyst 15.7. Your card should be wayyyy more than 2 fps ahead of my 7970GE/sandy bridge.
Reply 25 of 241, by Bullmecha
Tested on my Main PC.... no OC on it
Will add when i finish my P4 and AthlonXP builds as well.
Just a guy with a bad tinkering habit.
i5 6600k Main Rig
too many to list old school rigs
Reply 26 of 241, by joe6pack
I also had to run 64 bit, as 32 crashed on me. The results seem....very underwhelming. Then again, I'm very disappointed with the FX-8350. I'm jumping over to an i7-4790K as soon as I have the cash.
Reply 27 of 241, by obobskivich
Reply 28 of 241, by blank001
obobskivich wrote:
Yes. It's been pestering me for a driver update for a day or two now - I'll probably get around to it eventually (nothing I'm actually playing has any trouble, and I don't like to update things just for the sake of updating things/just for benching - if it ain't broke, don't fix it, and all that). 😊 As far as "way more than 2 FPS ahead" - there's been a 295X2 posted, and it "only" got ~10 FPS (~13%) higher than my 290X. I'm guessing there's some other bottleneck (CPU perhaps?) that it's running into on these systems.
We're doing the GPU benchmark, so you wouldn't expect it. I wish I understood the architecture better, but I suspect crysis isn't leveraging the newer tech in the cards.
Also, I get exactly the same result with 64 and 32 bits.
Reply 29 of 241, by PhilsComputerLab
blank001 wrote:
I'll definitely join. I would like to compete in the XP-32bit and W8.1 segment of the competition.
Should be fun finding the slowest system that will run it. Seeing how long it took my Pentium with 7600 GT, the benchmark could run hours on a really slow system 😊
Nope!
Half-way through the benchmark:
That sucks.
Does this happen every time?
FX 🤣 That would be a lag fest 😀 The specs mention 1 GB of memory, so should be to difficult to whip together a P4 with a FX.
seob wrote:
Just ran the bench in windows7 64-bit, 1920x1080 all high, But i get a strange overall average of 1929,5 fps while low is at 15,61 and high at 22,23.
Likely an issue with the decimal point. Are you in a country that uses the comma and not the dot? It's likely 19.295. The benchmark has stats on the top left while you're running, so you can compare it that way as well.
Not sure. But let us know!
YouTube, Facebook, Website
Reply 30 of 241, by Snayperskaya
Here's mine. 😀
Addes some more with different settings to compare.
Very High, 64-bit:
Run #1- DX10 1920x1080 AA=No AA, 64 bit test, Quality: VeryHigh ~~ Overall Average FPS: 6848,5
Very High, 32-bit:
Run #1- DX10 1920x1080 AA=No AA, 32 bit test, Quality: VeryHigh ~~ Overall Average FPS: 7470
Run #1- DX10 1920x1080 AA=4x, 32 bit test, Quality: VeryHigh ~~ Overall Average FPS: 6572,5
Run #1- DX10 1920x1080 AA=8xQ, 32 bit test, Quality: VeryHigh ~~ Overall Average FPS: 6783
Run #1- DX10 1920x1080 AA=16xQ, 32 bit test, Quality: VeryHigh ~~ Overall Average FPS: 6788
High:
Run #1- DX10 1920x1080 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 9398
Run #1- DX10 1920x1080 AA=4x, 32 bit test, Quality: High ~~ Overall Average FPS: 9137
Run #1- DX10 1920x1080 AA=8x, 32 bit test, Quality: High ~~ Overall Average FPS: 9204
Run #1- DX10 1920x1080 AA=8xQ, 32 bit test, Quality: High ~~ Overall Average FPS: 9203,5
Run #1- DX10 1920x1080 AA=16x, 32 bit test, Quality: High ~~ Overall Average FPS: 9193,5
Run #1- DX10 1920x1080 AA=16xQ, 32 bit test, Quality: High ~~ Overall Average FPS: 9202
Reply 31 of 241, by blank001
DX 9.0c is Geforce 6, I'm not sure if FX will run.
I'm going to attempt this on my A64 venice rig. It's basically perfect for minimum specs.
Reply 32 of 241, by RogueTrip2012
Here's a shot of my rig. Only overclock is the memory. default is 1600, atm I have it at 2000 and still have to play with timings some more, again.
> W98SE . P3 1.4S . 512MB . Q.FX3K . SB Live! . 64GB SSD
>WXP/W8.1 . AMD 960T . 8GB . GTX285 . SB X-Fi . 128GB SSD
> Win XI . i7 12700k . 32GB . GTX1070TI . 512GB NVME
Reply 33 of 241, by PhilsComputerLab
I don't want to know how long that benchmark will run 😁
Reply 34 of 241, by TeddyTheBear
32bit:
And 64bit:
Reply 35 of 241, by blank001
I know, it'll be painful, but it must be done. The 754 3200+ is a little too fast for minimum specs actually. I need a AXP 2800+. The 7800gs is perfect because it's about 6800GT/ultra speed, which is apparently the minimum and 9.0c.
Reply 36 of 241, by PhilsComputerLab
Trying to get it going my notebook but it crashes 🤣
Reply 37 of 241, by blank001
The min specs claim Athlon XP, so I'm guessing no. I see what you're saying here. The slowest CPU you could run is basically the slowest CPU you can get in an universal AGP motherboard. So the new question is, what is the slowest cpu/clockspeed you can run with a 9.0c card?
Reply 38 of 241, by smeezekitty
This is my main machine
Windows Vista
4 GB of RAM
Q9550
Radeon 7850
Not too bad. The benchmark is VERY jerky though
I might add that the demo is a non-trivial file size
Reply 39 of 241, by ZanQuance
Well, now I don't feel so bad 😉 it crashes every time on win7 32-bit, I might boot into XP or win7 64-bit and give it a go.
My current rig is a Core2 e8400 @3ghz on a XFX X790i ultra with 8gb ram @1333, and a GTX460 @800-gpu/1000-mem/1600-shader, crashes at stock gpu speeds also, w/latest drivers (<-culprit most likely).
