Quake 2 DOS 3DFX: Call to Testing [Voodoo Rush]
Reply 40 of 63, by Maraakate
it's MTRRLFBE LFB WC. You don't need the hyphen. But that's good to hear what machine are you on?
Reply 41 of 63, by amadeus777999
Atlon64/2000/225 fsb.
No VoodooRush card to test on unfortunately.
One thing I forgot to mention is that under Win98 in 1280x1024 there's a horizontal bar running from left to right at around 3/4 from the top of the screen. A few pixels high(~2-3 guesstimate) featuring various colors.
Reply 42 of 63, by Maraakate
That's odd I've never experienced that before. Are you talking specifically about building from the VS6 makefile or running the q2dos in a win98 dos box because that feature is somewhat unsupported.
What are your speeds comapred to the windows binaries of 3.20?
Reply 44 of 63, by amadeus777999
The scrambled color bars seem to be specific to the gfx driver/windows - they do also appear in Blood, but the card is new so I got the wrong impression that it had something to do with your port.
Quake II 3.20 .exe with '-nosound' gives
~158 fps @ 640x480 - marginally "faster".
Your pre-built software only .exe was used - seems I overlooked the link to the source.
Reply 45 of 63, by Maraakate
amadeus777999 wrote:
The scrambled color bars seem to be specific to the gfx driver/windows - they do also appear in Blood, but the card is new so I […]
For this test:
Win98(Dos'd and -nosound)
57.1 fps on timedemo1 @1280x1024 (~183%)
155.0 fps on timedemo1 @ 640x 480 (~ 150%)
Is this running q2dos.exe in a dosbox inside of Windows 98? If so, this sounds about right Windows has some sort of voodoo going on with regards to MTRR and their cut down DPMI that seems to allow it to be faster.
Reply 46 of 63, by Putas
It works, low resolution issues are still the same though.
Reply 47 of 63, by Maraakate
I was more concerned if it worked at all which is good to know. I don't think we'll be able to squeeze that much more performance out of it unless we entirely rewrote ref_gl to use the entire glide API instead omitting mesa entirely.
Reply 49 of 63, by amadeus777999
Maraakate wrote:
For this test: […]
For this test:
Yes, in Win98 and double click on a dos"box"-shortcut. Their vesa speed magic seems pretty impressive, although at certain resolution(> 800x600) the "color bar bonus" is setting in.
Reply 51 of 63, by _arti
szo wrote on 2015-09-08, 07:57:
Uploaded builds from latest code: […]
Software renderer only:
https://bitbucket.org/neozeed/q2dos/downloads … 50905_SWonly.7z
All features including 3dfx/gl:
https://bitbucket.org/neozeed/q2dos/downloads … 20150915_ALL.7z
Is there a chance someone backed those files up? Me too, fighting with Q2 and Rush right now 😀
Reply 53 of 63, by Maraakate
Nvm, I just uploaded latest builds to https://bitbucket.org/neozeed/q2dos/downloads/ . Let me know how you make out. If you're on a P3 the SSE builds are a bit faster. With a Rush I recommend using mesa 3 or sage.
Reply 55 of 63, by _arti
Ok, I downloaded Q2DOS_EXE_LATEST.7Z and here is, as follows:
- game runs only in DOS mode obviously (is there a version I could run directly from Win95?)
- when switched to 3dfx renderer it returns with error (pic rel)
My config: Pentium 150, Hercules Stingray 128/3D, 64MB RAM, Win95
Drivers: https://www.3dfxzone.it/dir/3dfx/drivers/?objid=727
Reply 56 of 63, by _arti
Missing picture:
453928977_960333435865064_1017304886441211967_n.jpg?_nc_cat=103&ccb=1-7&_nc_sid=9f807c&_nc_ohc=OEEIcUfG4S4Q7kNvgFEejBU&_nc_ht=scontent-waw2-1.xx&oh=03_Q7cD1QFPJTt-9X_iS-p6KlAgzgTLEtmQZGURrDdQNnJO-zFpmQ&oe=66E82C9F
Reply 57 of 63, by Maraakate
You have to pick the correct drivers and yes it will only run in true DOS. See readme.fx, voodoo\voodoo.txt and opengl\opengl.txt for more details.
Not sure what the Mod_NumForName issue is about. You are not using Q2 Remaster, etc. assets, correct?
Reply 58 of 63, by _arti
Nope, original installation from vanilla Q2 CD.
Reply 59 of 63, by Maraakate
You should update it to v3.20 first. There's probably modifications to the pak files (or additional ones I don't remember it's been years).
