First post, by ConjurerDragon
ConjurerDragon
Offline
- Newbie
I have reinstalled several old Sid Meier games and try to get them to run using DOSBOX 0.74 under D-Fend Reloaded.
The original Railroad Tycoon from 1991 works fine.
When using exactly the same settings for Railroad Tycoon Deluxe however it crashes to desktop whenever a graphic would need to be shown (e.g. when building a bridge the game would normally show a picture of a bridge but CTD).
The configuration I use is:
# This DOSBox configuration file was automatically created by D-Fend Reloaded.# Changes made to this file will NOT be transfered to D-Rend Reloaded profiles list.# D-Fend Reloaded will delete this file from temp directory on program close.# Command line used when starting DOSBox:# -CONF "...\Railroad Tycoon Deluxe.conf" -NOCONSOLE# Config file for profile "Railroad Tycoon Deluxe"[sdl]fullscreen=truefulldouble=truefullresolution=originalwindowresolution=originaloutput=overlayautolock=falsesensitivity=100waitonerror=trueusescancodes=truepriority=highest,highermapperfile=K:\D-Fend Reloaded\mapper.map[dosbox]machine=vesa_oldvbecaptures=K:\D-Fend Reloaded\Capture\Railroad Tycoon Deluxe\memsize=24[render]frameskip=0aspect=falsescaler=normal3x[cpu]core=normalcputype=autocycles=fixed 7000cycleup=500cycledown=20[mixer]nosound=falserate=44100blocksize=2048prebuffer=10[midi]mpu401=intelligentmididevice=defaultmidiconfig=[sblaster]sbtype=sb16sbbase=220irq=7dma=1hdma=5sbmixer=trueoplmode=autooplrate=44100oplemu=default
[gus]gus=falsegusrate=22050gusbase=240gusirq=5gusdma=1ultradir=C:\ULTRASND[speaker]pcspeaker=falsepcrate=44100tandy=offtandyrate=44100disney=false[dos]xms=trueems=trueumb=truekeyboardlayout=US[joystick]joysticktype=nonetimed=trueautofire=falseswap34=falsebuttonwrap=false[serial]serial1=disabledserial2=disabledserial3=disabledserial4=disabled[autoexec]@echo offSET PATH=Z:\keyb US 437mount C "K:\D-FEND~1\VIRTUA~1\"mount D "K:\MPS\SIDMEI~1\"echo.D:cd\Z:\config.com -securemode > nulRRT.EXEexit
