First post, by ConjurerDragon
I have reinstalled several old Sid Meier games and try to get them to run using DOSBOX 0.74 under D-Fend Reloaded.
The original Railroad Tycoon from 1991 works fine.
When using exactly the same settings for Railroad Tycoon Deluxe however it crashes to desktop whenever a graphic would need to be shown (e.g. when building a bridge the game would normally show a picture of a bridge but CTD).
The configuration I use is:
# This DOSBox configuration file was automatically created by D-Fend Reloaded.
# Changes made to this file will NOT be transfered to D-Rend Reloaded profiles list.
# D-Fend Reloaded will delete this file from temp directory on program close.
# Command line used when starting DOSBox:
# -CONF "...\Railroad Tycoon Deluxe.conf" -NOCONSOLE
# Config file for profile "Railroad Tycoon Deluxe"
[sdl]
fullscreen=true
fulldouble=true
fullresolution=original
windowresolution=original
output=overlay
autolock=false
sensitivity=100
waitonerror=true
usescancodes=true
priority=highest,higher
mapperfile=K:\D-Fend Reloaded\mapper.map
[dosbox]
machine=vesa_oldvbe
captures=K:\D-Fend Reloaded\Capture\Railroad Tycoon Deluxe\
memsize=24
[render]
frameskip=0
aspect=false
scaler=normal3x
[cpu]
core=normal
cputype=auto
cycles=fixed 7000
cycleup=500
cycledown=20
[mixer]
nosound=false
rate=44100
blocksize=2048
prebuffer=10
[midi]
mpu401=intelligent
mididevice=default
midiconfig=
[sblaster]
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
sbmixer=true
oplmode=auto
oplrate=44100
oplemu=default
…Show last 48 lines
[gus]
gus=false
gusrate=22050
gusbase=240
gusirq=5
gusdma=1
ultradir=C:\ULTRASND
[speaker]
pcspeaker=false
pcrate=44100
tandy=off
tandyrate=44100
disney=false
[dos]
xms=true
ems=true
umb=true
keyboardlayout=US
[joystick]
joysticktype=none
timed=true
autofire=false
swap34=false
buttonwrap=false
[serial]
serial1=disabled
serial2=disabled
serial3=disabled
serial4=disabled
[autoexec]
@echo off
SET PATH=Z:\
keyb US 437
mount C "K:\D-FEND~1\VIRTUA~1\"
mount D "K:\MPS\SIDMEI~1\"
echo.
D:
cd\
Z:\config.com -securemode > nul
RRT.EXE
exit
Reply 1 of 1, by ConjurerDragon
After trying even more different combinations the change from render:overlay to render:surface seems to work
