3dfx performance
First post, by Xelasarg
Hey all,
I'm trying to run Tomb Raider in 3dfx/Glide mode, but performance is abysmal. I remember that I played Tomb Raider some years ago at high cycle rates, and in an old thread from 2006, Great Hierophant says that "Tomb Raider is fluid at 25,000 cycles when in software mode it was choppy regardless of setting."
Now, on my system (Core i5), it runs fluid in SVGA (>100.000 cycles), but extremely choppy in 3dfx (6.000-15.000 cycles ingame, 2000 in start menu). I can't for the life of me figure out why that is. I'm using ykhwong's latest build, but also tried some of his older ones. I've also tried to copy the glide2x.ovl file to the game directory, but to no avail. Am I missing something obvious?
Thanks in advance, guys... 😀
"What's a paladin?!"
Reply 1 of 12, by Sammy
try:
glide=emu
voodoo=opengl
output=opengl
Reply 2 of 12, by Tertz
The best fps you may get in wrapper mode glide=true. You need glide wrapper like nglide to use it. In software mode fps may be low on modern CPUs.
DOSBox CPU Benchmark
Yamaha YMF7x4 Guide
Reply 3 of 12, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Yes, back then in 2006 you used the glide wrapper. These days you haveby default the built in voodoo emulation in daum builds... And that is costly.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 4 of 12, by Sammy
I think that Tomb Raider does not run with Wrapper because of the static linked exe?
Btw, the last daum version from 2015 is broken here... it did not use the wrapper, even if set glide to true.
Reply 5 of 12, by Xelasarg
Thanks for the info. That certainly explains the issues I'm having. 😉
But it's a shame, really, that I get only 10% performance with the latest 2015 build compared to a build from 2006, which was based on Dosbox 0.65, IIRC. 3dfx/Glide used to speed Dosbox up, whereas now, it slows everything down to a crawl. 😕
Is there no way to use an old Glide wrapper? Or will I simply have to scan the internet for a 2006 Daum build?
Reply 8 of 12, by Xelasarg
This is so weird... I've tried Dosbox-G, and it works - great performance (which is good news 😀 ). But the Daum builds seem to be fundamentally flawed. Even if I copy the Daum dosbox.exe into the Dosbox-G directory, so it's using the same files, it's still terribly slow. Damn, I'd really like to have access to the menu bar of the Daum builds, but one cannot have everything, right? 😉
Some curious things I've noticed:
Dosbox-G exe:
- 3dfx only works with glide=emu
- 3dfx splash screen is choppy, while
- Game menu and the game itself are running smooth as silk
Daum exe:
- 3dfx also works with glide=true, but only in its own install directory; when executed in the Dosbox-G dir, only glide=emu works
- 3dfx splash screen is super smooth, but
- game menu and the game itself are choppy as hell.
Ah well, I'll use Dosbox-G for now, too much bother trying to figure out what's broken in ykhwong's builds. Thanks for your help!
Reply 9 of 12, by Tertz
No, as Tomb Raider exists in nglide support list
You may try to use nglide, the last 2014 version of Daum build, its configuration file and correct settings to activate the wrapper.
Yamaha YMF7x4 Guide
Reply 10 of 12, by Gamecollector
Tomb Raider have two 3dfx executables. One (1114 kB) is statically linked, the other (874 kB) uses glide2x.ovl.
To use a wrapper (glide=true) you must use the second one.
Reply 11 of 12, by Sammy
Try daum build from Jan 2014.
There should glide=true work. (uses wrapper)
copy the glide2x.ovl from the dosbox dir to the tomb-raider directory (where the 3dfx-tomb.exe is)
and delete glide2x.dll from dosbox directory.
Reply 12 of 12, by Xelasarg
Oh man, I finally figured it out...
I was using output=ddraw and direct3d (both are incredibly slow in Daum), because opengl didn't work. But as it turns out, I had windowresolution set to custom size (1280x960), which breaks Glide along with opengl. Now, with windowresolution=original and output=opengl, I got the following result:
(To be honest, 760.000 is a show-off value, in the menu, I even reached >1.000.000 cycles.
In open spaces filled with enemies, this value drops to 120.000, but that's terrific nonetheless 😁 ).
All the time, I thought my issue couldn't be output related, because Dosbox-G was running fast no matter which video system I chose. I was using ddraw and direct3d parameters for both Daum and Dosbox-G, and opengl wasn't working for me in Daum. The only one I didn't try was surface, because I never use it (no scalers etc).
But as it turns out (by taking a closer look at the console window), ddraw and direct3d are actually deactivated in Dosbox-G, and it switches to openglnb automatically if direct3d or ddraw are selected in dosbox.conf. When I set output=surface, both Daum and Dosbox-G run slow. Holy mother of crap... 😉
Anyway, thanks for all your help, guys! 😀
