Reply 20 of 119, by PCBONEZ
wrote:I lucked out and 2/3 of my socket 370 boards use high quality caps. One is Dell and the other is an Asus board.
Dell, Supermicro and Intel went with all Japanese caps before the first wave of the capacitor plague hit.
Dell and Intel (and many others) took it in the shorts a little later when Nichicon (a Jap brand) screwed up some of their caps.
Call that second wave I guess?
At that time Supermicro was using Sanyo caps almost exclusively so they didn't have many (if any) affected boards.
Asus -usually- used bad caps then but some of their mucho expensive models got Rubycon or similar.
Probably due to production supply shortages sometimes the lesser Asus boards got Rubycon too, but that wasn't consistent and was luck of the draw.
I don't remember the real model but I remember looking at an ASUS (say) XYZ-Deluxe and comparing to their XYZ-(non Deluxe).
The Deluxe had Rubycons and the standard had OST. The Deluxe also cost like $100 more.
Abit and Gigabyte were fairly quick in switching to all Jap caps (Asus never did) but they got screwed right after with the Nichicon fiasco.
