First post, by Great Hierophant
101 Monochrome Mazes just does not look quite right in DOSBox. It is a text mode game intended solely for the original MDA (MDPA) and uses 80-column text. In DOSBox, it looks like this :
2.73 KiB
On a real MDA monitor with either an IBM MDA or Hercules card, it looks like this :
4.59 KiB
See here for pictures taken from the real monitor : http://www.vintage-computer.com/vcforum/showt … e-Compatibility
If the 9-pixel wide text boxes were added to the Hercules machine type, this would look correct.
Also, the game will work with an EGA card attached to an MDA monitor with some attribute differences, as identified in the link above. DOSBox just spits out the "Cannot run on a Color Card" error message. Just in case you wanted improve the EGA monochrome accuracy 😊
Reply 2 of 4, by ripsaw8080
Rank DOSBox Author
DOSBox Author
DOSBox is emulating a color monitor for EGA/VGA, not a mono monitor, and to run this game on such hardware you have to change to monochrome mode. Technically, it is changing the BIOS equipment list word to indicate monochrome instead of color and then setting mode 7, and this is easily done with the external MODE program from DOS (e.g. "MODE MONO").
If you switch to monochrome mode with machine=vgaonly then you will get 9-dot characters; and with machine=vgaonly in a recent SVN build you will get the 14-line font and 9-dot *wide* characters. However, the particular game in question uses MDA/Hercules text attributes in a way that EGA/VGA does not completely emulate, so machine=hercules is preferred for proper attributes. The Hercules emulation might be reworked for 9-dot text drawing at some point, but the current 8-dot drawing is a cosmetic issue at most.
Reply 3 of 4, by Great Hierophant
I tried this after compiling the latest SVN, but the height of the screen remains in 400 line mode after using MODE MONO in vgaonly machine type. The game will run and the attributes will be off in vgaonly. It will still complain about the color adapter in ega machine type. It does look like the EGA card did on my 5151.
I suppose that any emulated graphics that do not look as they should are "cosmetic issues" 😉 Aren't those 9th-column lines as sexy as tan lines?
Here are the main photos for those who are not VCF members :
96.54 KiB
95.38 KiB
Reply 4 of 4, by ripsaw8080
Rank DOSBox Author
DOSBox Author
You'll need to switch to EGA lines mode before switching to monochrome mode if you really want the 350-line mode with the 14-line font, but the attributes aren't going to become any more like MDA. And by cosmetic I mean that playability is not compromised; and some may even prefer not having the gaps between characters, seeing it as an eyesore rather than a point of historical accuracy. 😉
