First post, by Great Hierophant
- l33t
101 Monochrome Mazes just does not look quite right in DOSBox. It is a text mode game intended solely for the original MDA (MDPA) and uses 80-column text. In DOSBox, it looks like this :
On a real MDA monitor with either an IBM MDA or Hercules card, it looks like this :
See here for pictures taken from the real monitor : http://www.vintage-computer.com/vcforum/showt … e-Compatibility
If the 9-pixel wide text boxes were added to the Hercules machine type, this would look correct.
Also, the game will work with an EGA card attached to an MDA monitor with some attribute differences, as identified in the link above. DOSBox just spits out the "Cannot run on a Color Card" error message. Just in case you wanted improve the EGA monochrome accuracy 😊
