L2 Cache problem on 486 mainboard
First post, by srmeister
i got a problem with the L2 cache on my board. On the BIOS POST screen it shows up correctly but all the tools like speedsys and cachechk and others show that there is no L2 cache used.
Board is MSI MS-4144 rev.1.2 AMIBIOS AF53 (Issue Date: 1996/05/23)
CPU Intel 486DX2-66
48MB RAM
Installed is 256kb L2 Cache + 1 tag ram chip, according to manual (jumpers set correctly-BIOS recognizes the amount installed)
i tried 2 different Sets of Cache chips (20ns, 15ns) - both dont work. Also i tried 512kb according to manual, doesnt work either.
checked all BIOS settings, seems to be good.
Any ideas what could be wrong here?
Reply 1 of 20, by clueless1
Is it performing as if there is no cache? What are your 3dbench and pcpbench scores? Also doom (use Phil's DOS benchmark kit at www.philscomputerlab.com).
Reply 2 of 20, by kanecvr
Sounds like the cache jumpers are incorrectly configured or of the chips is damaged or missing. Make sure the chips are correctly oriented and pushed all the way into the sockets. It would also help to recheck if all of the pins made it into the sockets - more then once I noticed one leg of the cache chips did not make it into the socket.
Reply 3 of 20, by srmeister
Yes it is exactly performing as if there is no L2 cache installed, even though on the BIOS post screen, it shows the amount that i set up with the jumper block.
On cachechk it reports "it seems theres no L2 cache installed - check for fake cache"
On speedsys there is only one bump, in the region below 8kb (internal cache) after that there is a flat line. Also it mentions that there is no L2 cache.
Regarding the jumper settings- i triple checked them by now.
Regarding the IC pins - i checked them, the ICs are seated and all pins are in.
Here i took a picture of my configuration which is 256kb, 4x 64kb chips.
I got 2 sets of chips (i originally wanted to upgrade the board to 512kb), both sets get me the same result - that is no L2 cache is recognized.
    205.52 KiB
    192.87 KiB
    194.02 KiB
Reply 4 of 20, by srmeister
here are some more pictures
i hope anyone got another idea what could be wrong here.
thanks in advance,
srm.
    110.61 KiB
    speedsys only sees L1 cache
    124.95 KiB
    closeup
    132.27 KiB
    speedsys
    118.1 KiB
    POST screen says 256kb installed
Reply 5 of 20, by Tetrium
Move JS2 to 1-2?
My retro rigs (old topic)
Report spammers here!
Reply 8 of 20, by srmeister
i saw something really interesting.
on the pic from the mainboard you can see a free smd space where it reads "555". There is a smd resistor soldered between pins 1-2 that really looks odd. iam really not sure if this is some kind of manufacturing mistake or not...
Reply 9 of 20, by Tetrium
I was about to mention this...but I don't know.
I don't think I have this board so I can't check myself. But iirc it was a reasonably common 486 board so another Vogons member may have one
Reply 10 of 20, by srmeister
here is a close up of the odd smd part.
looking forward to hear your opinions
Reply 11 of 20, by Tetrium
I don't know for sure, but I wouldn't exclude the possibility that this was a factory fix. SMD has the same color as the ones near it and repairs of this sort were more common in those days.
Reply 12 of 20, by PCBONEZ
LM555 is a timer and it looks like the SMD is across what would be pins 3 and 4 which would be Output and Reset.
http://www.ti.com/lit/ds/symlink/lm555.pdf
Pic of a Ver 1.1 showing LM555 populated. http://www.elhvb.com/mobokive/archive/Microst … MSI_MS-4144.jpg
Pic of a Ver 1.5 with no LM555 and no SMD. http://www.amoretro.de/wp-content/uploads/msi … motherboard.jpg
Reply 14 of 20, by kanecvr
From the pic you posted it seems like the cache chips are set to bank 2? From what I can tell, the cache sockets are numbered V9, V11, V13, V15 and V19, V24, V28 etc. I see you have the cache chips plugged into the sockets with higher values. Try moving the cache chips in the other sockets, or try using 8 cache chips if you have them.
Reply 15 of 20, by Tetrium
I checked this yesterday and according to the manual the cache chips are seated in bank 1 (but I do agree with you it is odd practice to have the lower bank indicated with higher numbers, but strange things happen more often so it might still be the correct one). But as there seem to be problems remaining (and as sometimes manuals simply lie, especially the ones from those dark ages) he might as well give it a try in the other bank provided it won't hurt any of the components.
Reply 17 of 20, by srmeister
Thanks for your tips, problem is solved.
I reduced the RAM to 8MB - nothing.
I put the cache chips to bank 2 - nothing.
Then i thought i should read the f*ing manual page by page and check EVERY damn jumper on the board.
So i came across the CPU jumper settings page (see below) and the mainboard was jumpered as in the photo
so i put in the 3 more jumpers to JC5 and JC6 and now it works (see screenshot of cachechk).
JC8 is for the 1x or 2x CPU frequency (DX or DX2) see right page in the manual below. This at least was set correctly 😁
Thanks for all the help. Should have read every page of the damn manual earlier 🙁
i bought the machine with 256kb cache installed and with the CPU installed. I didnt change anything cpu related. So the mainboard+cpu did never run on full speed as it does now.
Next thing im gonna do is go for 512kb cache and maybe 40mhz FSB 😀
THANKS again!!
    179.98 KiB
    125.83 KiB
    212.18 KiB
Reply 18 of 20, by clueless1
Great! Glad you got it solved. These experiences not only help you but all of us who read along. I think mistakes likes this are wonderful learning opportunities. 😀
Reply 19 of 20, by Tetrium
Nice to see it's been solved and the board is working, yw 😀
