T7G saved games
First post, by xtgold
The DOS version of the seventh guest saved games are 291 bytes bigger than the win95 version,1315 vs 1024 and I couldn't find any saved games on the net for DOS.
I had to make my own attic level save game with a hex editor,I saw the pattern of ascii 1's and tried that 1st then the H's.You have to match the pattern of both 1's and H's like in the win95 version,then you can get into the attic to solve the last puzzle.
Also,the 1st bytes of the 1st line are the name of the file in ascii -10,as an example ATTIC in ascii is 41 54 54 49 43
but shows up on line 1 as 31 44 44 39 33.
You can load the DOS saved games in the win95 version and play,but not vice-versa.
The game actually fits on 1 cd,you can put both discs on 1 cd and play the DOS version totally.
The win95 version burps and keeps asking for disc 2.
Reply 1 of 2, by xtgold
decompressing the install.exe with unp411,we find:
00000000 656C 6563 7465 6400 546F 2075 7365 2074 elected.To use t
00000010 6865 2062 6574 612F 4345 5320 6465 6D6F he beta/CES demo
00000020 2064 6973 6B73 2C20 0A79 6F75 206D 7573 disks, .you mus
00000030 7420 7370 6563 6966 7920 2773 696C 7665 t specify 'silve
00000040 7227 206F 6E20 7468 6520 636F 6D6D 6D61 r' on the commma
00000050 6E64 206C 696E 650A 000A 616E 2045 5841 nd line...an EXA
00000060 4D50 4C45 206F 6620 7375 6368 2075 7361 MPLE of such usa
00000070 6765 2077 6F75 6C64 2062 653A 0A0A 494E ge would be:..IN
00000080 5354 414C 4C20 7369 6C76 6572 200A 0054 STALL silver ..T
which means there must have been a demo of the program originally.
Using "install silver" on the regular cd shows no difference in game play.
Reply 2 of 2, by xtgold
you don't have to use the ouija board to name the saved games,you can use the pc keyboard.
much faster.
